Upgrading from a hard drive should be easy and affordable and that's where OCZ Trion 150 SSDs come in. Designed to optimize and instantly boost the speed of your notebook or PC, the Trion 150 Series leverages premium Toshiba TLC NAND flash to go the distance and deliver a superior balance of performance, reliability, and value that will transform any mobile or desktop system.
Fast and Efficient
Up your productivity with the TR150 Series and enjoy faster boot ups, file transfers, and system responsiveness. Say goodbye to hard disk drive lag and get a computing experience worthy of your time.
Performance Made Affordable
Upgrading to an SSD from a conventional HDD can feel like you've purchased an entirely new system. TR150 SSDs balance price and performance so you have enough funds left over for other upgrades.
Better Battery Life
The more power-efficient TR150 Series provides lower consumption compared to HDDs, which can translate into longer battery life to keep you up and running longer.
Advanced Warranty Program
A new approach to service that mitigates the hassle surrounding support and warranty claims consumers often have to deal with. This program provides advanced replacement with no return shipping costs.
Fast and efficient
Up your productivity with the Trion 150 Series and enjoy faster boot ups, file transfers, and system responsiveness. Say goodbye to hard drive lag and get a state-of-the-art computing experience worthy of your time. -
Performance made affordable
Upgrading to an SSD can feel like you've purchased an entirely new system - not only because of the enhanced speed, but also the initial investment normally associated with the technology. Trion 150 SSDs balance price and performance so you have enough funds leftover for other upgrades. -
World-class quality and reliability
With 100% Toshiba technology built into every drive, each Trion 150 SSD is engineered for superior quality and reliability, keeping your data secure. -
Better battery life
The more power-efficient Trion 150 Series is optimized for lower energy consumption which translates into longer battery life to keep you up and running longer. -
Serious speed, zero tricks
Trion 150 offers plenty of real world performance for all your gaming and productivity applications. No fancy behind-the-scenes tricks, just pure storage performance.
- OCZ Trion 150 - solid state drive - 120 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 120 GB
- NAND Flash Memory Type
- 15nm triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- TRIM support, S.M.A.R.T.
- 69.85 mm x 100 mm x 7 mm
- 48 g
- 3-year warranty
- Capacity
- 120 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100 mm
- 7 mm
- 48 g
Performance
- Internal Data Rate
- 550 MBps (read) / 530 MBps (write)
- 4KB Random Write
- 3600 IOPS
- Maximum 4KB Random Write
- 64000 IOPS
- Maximum 4KB Random Read
- 90000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 4.8 Watt (active) , 830 mW (idle) , 6 mW (sleep)
- CSA, UL, C-Tick, BSMI, FCC, KCC, WEEE
- Limited warranty - 3 years
- 0 °C
- 65 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms
- Vibration Tolerance (operating)
- 20 g @ 10-2000 Hz
