Get fast performance and work interactively with models and scenes across CAD, DCC, and medical applications with the new Maxwell GPU architecture features of the flexible, single-slot NVIDIA Quadro M2000 graphics card.
Experience ultra-fast visualization and compute horsepower with 4GB ultra-fast GDDR5 memory and CUDA® parallel processing.
Drive up to four 4K or two 5k displays or one 8K projector with four DisplayPort 1.2 ports and managed them with included NVIDIA® Mosaic™ and NVIDIA® nView® technologies. Enable immersive collaboration with optional 3D Vision™ and 3D Vision Pro.
Boost application performance in real time while staying within the power and thermal envelope of the card with NVIDIA® GPU Boost.
Easily support your professional software application base with comprehensive ISV certifications.
Compatible with Z240 CMT, Z440, Z640, Z840.
High-speed compute power
Experience ultra-fast visualization and compute horsepower with 4GB ultra-fast GDDR5 memory and CUDA parallel processing. -
One card, many display possibilities
Drive up to four 4K or two 5k displays or one 8K projector with four DisplayPort 1.2 ports and managed them with included NVIDIA Mosaic and NVIDIA nView technologies. Enable immersive collaboration with optional 3D Vision and 3D Vision Pro. -
Integrated NVIDIA GPU Boost
Boost application performance in real time while staying within the power and thermal envelope of the card with NVIDIA GPU Boost. -
Certified for your most common ISVs
- NVIDIA Quadro M2000 - graphics card - Quadro M2000 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- Memory
- 4 GB GDDR5
- CUDA Cores
- 768
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DisplayPort: 4096 x 2160 at 60 Hz / DisplayPort: 2560 x 1600 at 120 Hz
- Max Monitors Supported
- 4
- Interfaces Details
- 4 x DisplayPort (HDCP)
- API Supported
- OpenCL, DirectCompute 5.0, DirectX 12, OpenGL 4.5
- 16.7 cm x 11 cm
- Pricing Type
- Promo
- Designed For
- Workstation Z240 (MT, tower), Z440, Z640, Z840
- Graphics card
- Bus Type
- Graphics Engine
- CUDA Cores
- 768
- Max Resolution
- 4096 x 2160 at 60 Hz
- 4
- API Supported
- Nvidia CUDA technology, NVIDIA Mosaic, NVIDIA GPU Boost, Multi-Stream Technology, Maxwell architecture, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 128-bit
- Bandwidth
- 105.7 GBps
- OS Required
- Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
- 75 Watt
- 16.7 cm
- 11 cm
- 230 g
- Pricing Type
- Promo
- Designed For
- HP Workstation Z240 (MT, tower), Z440, Z640, Z840
