Product
Nuance Nuance Omnipage Std  V18
Quicklinx: 7KH7WS00 Mfr#: 2889X-W00-18.0
Type: Utilities - OCR software
Compatibility: PC
License: Box pack
Media: CD-ROM
£58.92 ex VAT
£70.70 inc VAT
Don't retype your documents - convert them! OmniPage 18 is the fastest and most precise way to convert paper, PDF files, and even digital camera pictures into documents you can edit in your favorite PC applications. OmniPage 18 delivers unrivaled accuracy, speed, and innovative features.
As the industry-leading solution, OmniPage 18 delivers the most accurate document conversion available, turning paper and PDF files into electronic files you can edit, search, and share. In addition, OmniPage 18 ensures that your converted electronic documents look exactly like the original - complete with text, graphics, columns, and tables.
All of this means OmniPage 18 will significantly reduce the amount of time spent converting important files, so you can focus on more important business goals.
  • Start page provides guidance
    When OmniPage opens it presents clear options to open or scan documents, open OmniPage project documents and provides pre-programmed workflows to take your documents from one format to another in one easy step.
  • Productive and accurate searchable PDF - eDiscovery Assistant for searchable PDF
    PDF files are everywhere and can come from a variety of sources. They can include scanned pages, embedded images, and other types of information. Many of these elements don't include searchable text. Th eDiscovery Assistant for searchable PDF is a revolution in safely converting a single PDF or batches of PDFs of all types into completely searchable documents.
  • Better scanned images produces better accuracy
    The algorithms for removing speckles and dots from page images to help increase accuracy are improved, with a choice of despeckling methods.
  • Poorly scanned images need OmniPage with scanner enhancement tools
    When whiteboard content is captured by digital camera, the text and diagrams can be enhanced for maximum readability. Auto-crop pages to have margins detected and reduced; the punch hole remover and border tools produce clean page borders without scanning shadows and marginal notes.
  • Automatic language detection
    Let the program assign a single language to each incoming page during unattended processing. When this feature is enabled, no manual language selection is necessary.
  • Better control over determining blank pages
    A sensitivity setting increases the accuracy of recognizing blank pages that may scan as light gray or colored pages by allowing the threshold for blankness to be adjusted.
  • Superior word accuracy
    Transform words on paper and in images to accurate text for the best conversion and archiving of any document.
  • Perfect formatting
    Converted documents look exactly like the original - complete with columns, tables, bullets, and graphics - and are easier to edit than ever before.
  • Simply the easiest to use
    Converting documents doesn't have to be complicated. The start page gets it done in seconds so there's no need to learn a lot of options and tools.
  • One-click workflows
    Use the built-in workflows or create your own to get recurring conversion jobs done with just a push of a button.
  • Unlock PDF files
    Use the eDiscovery Assistant to keep originally searchable content intact and process just the non-searchable elements. You don't have to open PDF files one by one, or use an OCR process that might unintentionally wipe out valuable information.
  • Send to Amazon Kindle
    Scan a document, automatically convert into a readable format and send it to the Amazon Kindle electronic book reader in one easy step.
  • Automatically process emailed documents
    You can receive scanned papers or PDFs. OmniPage 18 will automatically convert them and save them in your preferred format.
  • A picture is worth a thousand words
    Use images from iPhone, iPad, or a digital camera and convert them into a readable format for mobile devices and electronic book readers.
OmniPage (v. 18) - box pack - 1 user
Box pack
Category
Version
18
Licence Qty
1 user
Platform
Windows
Language
English
Distribution Media
CD-ROM
Category
Box pack
Version
18
Platform
Windows
Distribution Media
CD-ROM
Language
English
Min Supported Colour Depth
16-bit (64k colours)
Licencing
Licence Type
1 user
Supported OS
Microsoft Windows Vista (32/64 bits) SP2, Microsoft Windows XP SP3, Microsoft Windows 7 (32/64 bits)
Additional Requirements
Sound card, CD-ROM, speakers, scanner, digital camera, graphics card, XGA monitor, Internet connection
Compatibility: PC
License: Box pack
Media: CD-ROM
Brand: Nuance
Price Range Ex VAT: 50 - 100
