Your basket is empty
Nokia Wireless Charging Stand DT910 BLACK
Quicklinx: 8MKHWS00 Mfr#: 02734W5
Go straight to charge
Think of the time spent recharging your phone. Finding the fiddly connector. Making sure it's the right way up. Plugging it in. All now a thing of the past. Simply place on the stand and your phone charges wirelessly. When the indicator light turns off, it's fully charged and ready for take-off.
Keep up with the action
Need to use your phone while it charges? No problem. Just tap via NFC to launch your chosen app, place phone on the stand and you are in business. Watch a slide show. Listen to music. Talk to mates. It's your call. Your phone even sits upright so you can see the screen clearly and stay involved with everything that's going on.
Nokia DT-910 - wireless charging stand
Wireless charging stand
11.2 cm
Diameter
8.5 cm
111 g
AC 100-240 V ( 50 - 60 Hz )
Voltage Provided
12 V
Lumia 720, 820, 920
11.2 cm
Diameter
8.5 cm
111 g
Enclosure Colour
Input Connector(s)
Power DC jack 2.5 mm
Voltage Provided
12 V
Max Electric Current
750 mA
LED indicator
Power cable - 1.8 m
WPC
Nokia Lumia 720, 820, 920
