- Nokia AC-60X power adapter - USB
- Product Type
- Power adapter
- 3.8 cm x 2.1 cm x 6.95 cm
- 33 g
- Localisation
- United Kingdom
- Output Connector Type
- USB - on cable: Micro-USB
- Voltage Required
- AC 100-240 V (50 - 60 Hz)
- Voltage Provided
- 5 V
- Max Electric Current
- 1500 mA
- Cables
- Micro-USB to USB cable
- Designed For
- Nokia X Dual SIM, XL Dual SIM; Lumia 1320, 1520
- Product Type
- Power adapter
- 3.8 cm
- 2.1 cm
- 6.95 cm
- 33 g
- Localisation
- United Kingdom
- Voltage Required
- Input Connectors
- Power BS 1363
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 1500 mA
- Cables Included
- Designed For
- Nokia X Dual SIM, XL Dual SIM , Nokia Lumia 1320, 1520
