Nokia 8 dual-SIM 4G 64GB 5.3" 4GB 13MP Android Smartphone - Steel
Quicklinx: DBKMWS00 Mfr#: 11NB1S01A11
  • microSDHC
  • Android
The Nokia 8 undergoes a rigorous 40-stage process of machining, anodizing and polishing to ensure its distinctive design pairs flawlessly with the polished aluminum unibody. The ultimate in seamless unibody construction, Nokia 8 is designed to nestle perfectly in the palm of your hand.
A first for mobile phones, the exclusive Dual-Sight mode lets you use both front and back cameras simultaneously for split-screen photos and video.
Nokia 8 features a 13 MP dual image-fusion rear camera with both color and monochrome sensors, plus a wide-angle 13 MP phase detection auto-focus front camera. Both front and rear cameras are equipped with ZEISS optics, meaning every snapshot moment becomes a story worth sharing.
  • Made with ultimate craftsmanship
  • Dual-Sight mode
  • Super-slim cameras with ZEISS optics
  • Hollywood technology in the palm of your hand
    For immersive video capture and a playback experience to match, the Nokia 8 is the first ever phone to feature Nokia OZO spatial 360° audio built in to its core. Capture moments with tech used by Hollywood filmmakers and music producers, then relive them as if you never left.
  • Powerful Android smartphone
    To maximize performance, Nokia 8 is built upon the cutting-edge Qualcomm Snapdragon 835 Mobile Platform, engineered to deliver exceptionally long battery life. They have also added a full-length copper cooling pipe with graphite shield to dissipate system heat across the full body of the phone.
Nokia 8 - steel - 4G smartphone - 64 GB - GSM
4G smartphone
Display
LCD display - 2560 x 1440 pixels - 5.3" - IPS - Corning Gorilla Glass 5 (scratch resistant glass)
Qualcomm Snapdragon 835 2.5 GHz (8-core) - 64-bit
RAM 4 GB / 64 GB
Supported Memory Card
microSDXC slot - up to 256 GB
Operating System
Android 7.1.1 Nougat
Main Camera
13 Megapixel - f/2.0 - focus: automatic laser auto focus: - laser focus
Second Camera
13 Megapixel
Front Camera
13 Megapixel - wide-angle lens - f/2.0 - automatic
Service Provider
Not specified
SIM Card
Dual-SIM (SIM1 and SIM2/MicroSD slots) - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Protection
Splashproof
Steel
73.7 mm x 7.9 mm x 151.5 mm
0.711 W/kg (head) , 1.33 W/kg (body) , 3.99 W/kg (limb)
Smartphone
Touch
Protection
Splashproof
73.7 mm
7.9 mm
151.5 mm
Body Colour
Steel
Body Material
6000 Series aluminium alloy
SAR Value
1.33 W/kg (body), 0.711 W/kg (head), 3.99 W/kg (limb)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Intelligent Assistant
Google Assistant
Navigation
GPS, A-GPS, GLONASS, BeiDou
SIM Card Type
Nano SIM
SIM Card Qty
SIM Card Configuration Details
Nano SIM + nano SIM/microSD
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0, ANT+/ANT
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, gyro sensor, hall sensor
Security Devices
Fingerprint reader
Android Enterprise Recommended
Additional Features
MIMO technology, Three microphones, Nokia OZO spatial 360° audio
Clock Speed
2.5 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
LPDDR4X SDRAM - 4 GB
Internal Memory Capacity
64 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 256 GB
Front Camera
Sensor Resolution
13 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/2.0
Focus Adjustment
Automatic
Video Resolutions
3840 x 2160 (4K)
Light Source
Display flash
Phase Detect Auto-Focus (PDAF)
Main Camera
Sensor Resolution
13 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/2.0
Focus Adjustment
Automatic
Laser Auto Focus
Light Source
Dual LED flash
Carl Zeiss optic, Phase Detect Auto-Focus (PDAF), Dual-tone Flash, IR range finder, Dual-Sight mode
Second Camera
Sensor Resolution
13 Megapixel
Display
LCD display
IPS
Diagonal Size
5.3"
Display Resolution
2560 x 1440 pixels
Display Format
QHD
Protection
2.5D Glass
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
3090 mAh
IP54
Data cable, headset, power adapter, SIM card removal tool
