Fully immerse yourself in your videos with PureDisplay - exclusive to Nokia smartphones. All footage is transformed, in real time, to high dynamic range (HDR), meaning more vibrant colors and a clearer picture. Plus, you can delight in every second from an impressive Full HD+ screen.
A billion shades of color in a single video
With the dedicated Pixelworks visual processor, all your videos get glorious color upgrades in real time. So instead of 17 million shades of color, Nokia 6.2 displays up to a billion shades for a seriously eye-catching experience. -
A bright screen - even outside
Can't see your screen in the sunshine? No problem for Nokia 6.2. The high brightness and local contrast enhancement deliver a stunning display - anytime, anywhere. -
Looks good
Nokia 6.2 is composed of a high-tech polymer composite frame that wraps around a solid metal core. The result? A lighter, stronger, sleeker design you can rely on. -
Solid glass
Designed with gently curving 2.5D Corning Gorilla Glass on both sides for a polished, mirror finish with a tough resistance to damage. -
Stunningly smooth finish
The unique metallic finish with nano coating not only gives your phone a stunning design but also durability against scratches.
- Nokia 6.2 - Android One - ceramic black - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Display
- - 6.3" - PureDisplay - HDR - Corning Gorilla Glass 3 (scratch resistant glass)
- FM radio
- Processor
- Qualcomm Snapdragon 636 (8-core) - 64-bit
- Memory
- RAM 3 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 512 GB
- Operating System
- Android 9.0 Pie
- Main Camera
- 16 Megapixel
- Second Camera
- 5 Megapixel - depth sensor
- Third Camera
- 8 Megapixel - ultra wide-angle lens
- Front Camera
- 8 Megapixel
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Ceramic black
- 75.15 mm x 8.25 mm x 159.92 mm
- 180 g
- Specific Absorption Rate (SAR)
- 0.975 W/kg (head) , 1.42 W/kg (body)
- Product Type
- Smartphone
- Form Factor
- Touch
- Integrated Components
- FM radio
- 75.15 mm
- 8.25 mm
- 159.92 mm
- 180 g
- Body Colour
- Ceramic black
- Body Material
- Metal, Corning Gorilla Glass 3, 2.5D glass
- SAR Value
- 1.42 W/kg (body), 0.975 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- Intelligent Assistant
- Google Assistant
- Navigation
- GPS, A-GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 850, 900
- 4G LTE Band
- Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 28, Band 38, Band 40, Band 41
- 4G LTE Frequency
- FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
- NFC, IEEE 802.11b/g/n/ac, Bluetooth 5.0
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, digital compass, gyro sensor, RGB sensor, distance sensor
- Security Devices
- Additional Features
- Dual microphones, Google Assistant Button
Media Player
- Sound Enhancements
- Qualcomm aptX audio
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 3 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 512 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
Main Camera
- Sensor Resolution
- 16 Megapixel
- Light Source
- LED flash
Second Camera
- Sensor Resolution
- 5 Megapixel
- Sensor Type
- Depth sensor
Third Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Ultra wide-angle lens
Display
- Technology
- PureDisplay
- Diagonal Size
- 6.3"
- Display Format
- Full HD+
- HDR
- Protection
- 2.5D Glass
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 3500 mAh
- Included Accessories
- Headset, power adapter, SIM card removal tool, USB-C cable
