Sleek curved design meets pure Android™ experience
• Seamless aluminium unibody
• 5.2" polarized HD display with sculpted Corning® Gorilla® Glass
• Fingerprint sensor for extra convenience
Quality you can feel in every detail
We designed Nokia 5 with our hallmark attention to detail. The smooth, minimalist body is made from a single piece of precision-milled aluminium with great care in order to give the phone added durability. The organic form nestles perfectly in your hand.
Beautifully seamless craftsmanship
Nokia 5 has a totally clean, pure back without any antenna lines, which have been moved to the top and the bottom of the phone. Together with the display with sculpted Corning® Gorilla® Glass, this makes for a clean look unspoilt by seams or lines.
Smartphones for life
For decades, Nokia phones have stood for beautiful, crafted design and excellent quality. This phone is no different: it’s built to take on life as you know it – with durable and beautiful materials, great feel, and an ideal balance of performance and battery life. What’s best, your Nokia phone will stay secure and up to date with regular software updates.
Get snap-happy with the 13 MP autofocus camera
Getting great photos with Nokia 5 is easy: automatic scene detection helps you get good shots wherever you are, while colours look natural thanks to the dual-tone flash.
Get the brighter display experience
Good-looking photos, natural colours and excellent brightness – say hello to Nokia 5’s fully-laminated 5.2" HD display. What’s best, the polarizer makes your content easy to read even in bright sunlight.
Pure, secure and up to date
Nokia 5 comes with Android Nougat, the full spread of Google Services and no unnecessary extras. You get an experience that’s focused and clutter-free, and we’ll make sure you keep getting regular updates, so you’ll always stay on top of features and security.
Nokia 5 has a totally clean, pure back without any antenna lines, which have been moved to the top and the bottom of the phone. Together with the sculpted Corning Gorilla Glass display, this makes for a clean look unspoiled by seams or lines. -
Nokia phones have stood for beautiful, crafted design and excellent quality. This phone is no different: it's built to take on life as you know it - with durable and beautiful materials, great feel, and an ideal balance of performance and battery life. Your Nokia phone will stay secure and up to date with regular updates. -
Get snap-happy with the 13MP autofocus camera
Getting great photos with Nokia 5 is easy: automatic scene detection helps you get good shots wherever you are, while colors look natural thanks to the dual-tone flash. -
Fit more into your selfies
Fit all of your friends into a group selfie with the 8MP wide-angle lens on the front. -
Take better photos at night
Your night-time photos just got upgraded, thanks to the Nokia 5's phase detection autofocus, wide aperture and dual-tone flash. That's a fancy way of saying, that you get great pictures, even in low light. -
Good-looking photos, natural colors and excellent brightness - say hello to Nokia 5's fully-laminated 5.2" display. The polarizer makes your content easy to read even in bright sunlight.
- Nokia 5 - copper - 4G smartphone - 16 GB - GSM
- Product Type
- 4G smartphone
- Display
- LCD display - 1280 x 720 pixels - 5.2" - IPS - Corning Gorilla Glass (scratch resistant glass)
- Processor
- Qualcomm Snapdragon 430
- Memory
- RAM 2 GB / 16 GB
- Supported Memory Card
- microSDXC slot - up to 128 GB
- Operating System
- Android 7.1.1 Nougat
- Main Camera
- 13 Megapixel - f/2.0 - focus: automatic
- Front Camera
- 8 Megapixel - wide-angle lens - f/2.0 - automatic
- Service Provider
- Not specified
- SIM Card
- Single-SIM
- Wireless Interface
- Wi-Fi, NFC, Bluetooth
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Copper
- 72.5 mm x 8.05 mm x 149.7 mm
- Product Type
- Smartphone
- Form Factor
- Touch
- 72.5 mm
- 8.05 mm
- 149.7 mm
- Body Colour
- Copper
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 850, 900
- 4G LTE Band
- Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 28, Band 38, Band 40
- 4G LTE Frequency
- FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300
- Wi-Fi, NFC, Bluetooth 4.1
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, digital compass, gyro sensor, hall sensor
- Security Devices
Media Player
- Audio Amplifier
- TFA9891
- RAM
- 2 GB
- Internal Memory Capacity
- 16 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 128 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/2.0
- Focus Adjustment
- Automatic
Main Camera
- Sensor Resolution
- 13 Megapixel
- Lens Aperture
- F/2.0
- Focus Adjustment
- Automatic
- Light Source
- Dual LED flash
- Phase Detect Auto-Focus (PDAF)
Display
- LCD display
- Technology
- IPS
- Diagonal Size
- 5.2"
- Display Resolution
- 1280 x 720 pixels
- Display Format
- HD
- Max Brightness
- 500 cd/m²
- Protection
- 2.5D Glass, Sunlight Display
- Connector Type
- Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
- Capacity
- 3000 mAh
- Included Accessories
- Headset, USB cable, power adapter, SIM card removal tool
