Nokia 5.1 16GB 5.5" HD+ Display - Black
Quicklinx: DXM1WS00 Mfr#: 11CO2B01A11
Colours:
  • microSDHC
  • Android
Nokia 5.1
A timeless classic refined
Premium craftmanship
Sculpted from a single block of aluminum, the new Nokia 5 goes through a precise machining process to achieve its refined look. From the beautifully rounded corners to the perfect way it fits in your hand, every detail shows a dedication to high-quality craftmanship.
Bigger screen, higher resolution
The upgraded Nokia 5 has a big Full HD+ 5.5’’ IPS display with an 18:9 ratio that’s ideal for watching videos, browsing and gaming. And the higher resolution ensures the content looks sharper as well as bigger.
Group selfies made easy
The new Nokia 5 features a 16 MP main camera with phase detection auto-focus, a faster and more reliable auto-focus system that lets you capture every detail. And the 8 MP front camera is equipped with an 84.6° field of view that fits the whole party in the same frame
Customized performance
The 2.0 GHz Octa-Core processor in the new Nokia 5 runs smoothly whether you’re messaging, browsing, gaming or switching between all three.
The best of Android™, latest innovation from Google
Android One brings a Google designed software experience to the new Nokia 5. Get everything you want and nothing you don’t with a streamlined, easy to use interface and a curated set of pre-installed apps, and free, unlimited high quality photos storage2 with Google Photos. Regular security updates and two years of OS upgrades means the new Nokia 5 with Android One stays secure and features the latest Google innovations like being optimized for the Google Assistant.
What's in the box
Your new Nokia 5.1
5V/2A charger
Micro USB cable
Quick guide
SIM door key
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
  • Bigger screen, higher resolution
    The upgraded Nokia 5 has a big Full HD+ 5.5'' IPS display with an 18:9 ratio that's ideal for watching videos, browsing and gaming. And the higher resolution ensures the content looks sharper as well as bigger.
  • Group selfies made easy
    The new Nokia 5 features a 16 MP main camera with phase detection auto-focus, a faster and more reliable auto-focus system that lets you capture every detail. And the 8 MP front camera is equipped with an 84.6° field of view that fits the whole party in the same frame.
  • Customized performance
    The 2.0 GHz Octa-Core processor in the new Nokia 5 runs smoothly whether you're messaging, browsing, gaming or switching between all three. You can also choose the RAM, storage and MicroSD card size that serve you best.
Nokia 5.1 - Android One - black - 4G - 16 GB - GSM - smartphone
Smartphone 4G
Display
LCD display - 5.5" - 18:9 - IPS - Corning Gorilla Glass 3 (scratch resistant glass)
Rear-facing camera, front-facing camera
MediaTek Helio P18 MT6755S / 2 GHz (8-core) - 64-bit
16 GB - RAM 2 GB + microSDXC slot - up to 128 GB
Operating System
Android Oreo
Rear Camera
16 Megapixel focus: automatic
Front Camera
8 Megapixel - focus free
Service Provider
Not specified
SIM Card Qty
Single-SIM
Wireless Interface
Wi-Fi, Bluetooth
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, Micro-USB
Talk Time
Up to 1140 minutes
Standby Time
Up to 588 hours
70.73 mm x 8.27 mm x 151.1 mm
Smartphone
Touch
Integrated Components
Rear-facing camera, front-facing camera, audio player, voice recorder, navigation
70.73 mm
8.27 mm
151.1 mm
Body Colour
Body Material
6000 Series aluminium alloy
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android Oreo
Navigation
GPS, A-GPS, GLONASS
SIM Card Qty
Single-SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Supported Social Networks and Blogs
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
Wireless Interface
IEEE 802.11a/b/g/n, Bluetooth 4.2
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, gyro sensor, G-sensor
Android Enterprise Recommended
MediaTek Helio P18
Processor Number
MT6755S
Clock Speed
2 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
2 GB
Internal Memory Capacity
16 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 128 GB
Front Camera
Sensor Resolution
8 Megapixel
Focus Adjustment
Focus free
Rear Camera
Sensor Resolution
16 Megapixel
Focus Adjustment
Automatic
Light Source
Dual tone LED flash
Phase Detect Auto-Focus (PDAF)
Display
LCD display
IPS
Diagonal Size
5.5"
Display Format
Full HD+
Aspect Ratio
18:9
Protection
Connector Type
Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
2970 mAh
Talk Time
1140 minutes
Standby Time
588 hours
Run Time Details
Talk: up to 1140 min , Standby: up to 588 hrs , Playback (Music): up to 52.7 hrs , Playback (video (1080p)): up to 9.4 hrs
USB cable, power adapter, SIM card removal tool
