Whether you're watching a movie or video chatting with friends, the display with a 19:9 ratio makes you feel like you're right there with them. The edge-to-edge design makes the most of every millimeter giving you more to see.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
Polished to perfection
Nokia 5.1 Plus is all about the details. Its high-gloss body creates a polished look, while the protective CNC-machined metal camera bezel lends a bold finish. -
More fun
This one is for the more demanding mobile gamers and on-the-go watchers. With optimized power consumption, your escape into TV shows or gaming sessions will last that little bit longer.
- Nokia 5.1 Plus - Android One - gloss black - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Display
- - 5.8" - 19:9
- Processor
- MediaTek Helio P60 1.8 GHz (8-core) - 64-bit
- Memory
- RAM 3 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 400 GB
- Operating System
- Android 9.0 Pie
- Main Camera
- 13 Megapixel - f/2.0 - focus: automatic
- Second Camera
- 5 Megapixel - depth camera
- Front Camera
- 8 Megapixel f/2.2 - focus free
- Service Provider
- Not specified
- SIM Card
- Single-SIM
- Wireless Interface
- Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Gloss black
- 71.98 mm x 8.096 mm x 149.51 mm
- Specific Absorption Rate (SAR)
- 0.778 W/kg (head) , 1.885 W/kg (body)
- Product Type
- Smartphone
- Form Factor
- Touch
- 71.98 mm
- 8.096 mm
- 149.51 mm
- Body Colour
- Gloss black
- SAR Value
- 1.885 W/kg (body), 0.778 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- Navigation
- GPS, A-GPS, GLONASS, BeiDou, Galileo
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- IEEE 802.11a/b/g/n/ac, Bluetooth 4.2
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, gyro sensor
- Security Devices
- Additional Features
- Dual microphones, Google Lens
- Clock Speed
- 1.8 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 3 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 400 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Focus free
- Field of View (FoV)
- 80.4 degree(s)
Main Camera
- Sensor Resolution
- 13 Megapixel
- Lens Aperture
- F/2.0
- Focus Adjustment
- Automatic
- Camera Modes
- Motion Photos
- Light Source
- LED flash
- Phase Detect Auto-Focus (PDAF)
Second Camera
- Sensor Resolution
- 5 Megapixel
- Functions
- Depth camera
Display
- Diagonal Size
- 5.8"
- Display Format
- HD+
- Aspect Ratio
- 19:9
- 2.5D Glass, Edge-to-Edge screen
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 3060 mAh
- Included Accessories
- USB cable, power adapter
