Nokia 3.1 (2018) 5.2" 13MP 16GB Android - Black
Quicklinx: DPRYWS00 Mfr#: 11ES2B01A21
  • microSDHC
  • Android
Nokia 3.1
Your premium companion
A design worth treasuring
The new Nokia 3 looks and feels premium. It draws attention with its subtle curves and striking diamond-cut aluminium sides. And with its curved back and sculpted Corning® Gorilla® Glass display, the new Nokia 3 nestles comfortably in your hand.
The perfect screen ratio
A compact device with maximized screen space. The 18:9 ratio in the new Nokia 3 is perfect for getting the most out of its 5.2’’ HD+ display whether you’re watching films or feeds – no more missed screen space.
Sharper, more detailed photos
The 13 MP auto-focus rear camera with LED flash let you capture crisp photos whether you’re out and about or indoors. And the 8 MP front camera with a wide 84.6-degree field of view is perfect for taking group selfies.
The best apps at your fingertips
The powerful Octa-Core processor in the new Nokia 3 lets you experience more, whether you’re playing AR games or multitasking between apps. You’ll also enjoy secure access to useful apps like Google Pay.
The best of Android™, latest innovation from Google
Android One brings a Google designed software experience to the new Nokia 3. Get everything you want and nothing you don’t with a streamlined, easy to use interface and a curated set of pre-installed apps, and free, unlimited high quality photos storage?with Google Photos. Regular security updates and two years of OS upgrades means the new Nokia 3 with Android One stays secure and features the latest Google innovations like being optimized for the Google Assistant.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
Nokia 3.1 - Android One - black/chrome - 4G - 16 GB - GSM - smartphone
Smartphone 4G
Display
LCD display - 5.2" - 18:9 - Corning Gorilla Glass (scratch resistant glass)
Rear-facing camera, front-facing camera, digital player
MediaTek MT6750N / 1.5 GHz (8-core) - 64-bit
16 GB RAM 2 GB
Supported Memory Card
microSDXC slot - up to 128 GB
Operating System
Android 8.0 Oreo
Rear Camera
13 Megapixel - wide-angle lens - f/2.0 - focus: automatic
Front Camera
8 Megapixel f/2.0 - focus free
Service Provider
Not specified
SIM Card Qty
Dual-SIM
Wireless Interface
Wi-Fi, Bluetooth
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Black/chrome
68.65 mm x 8.7 mm x 146.25 mm
138.3 g
SAR
1.63 W/kg (body), 0.64 W/kg (head), 3.99 W/kg (limb)
Smartphone
Touch
Integrated Components
Rear-facing camera, front-facing camera, voice recorder, navigation, digital player
68.65 mm
8.7 mm
146.25 mm
138.3 g
Body Colour
Black/chrome
SAR Value
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 8.0 Oreo
Navigation
GPS, A-GPS, GLONASS, BeiDou
SIM Card Qty
Dual-SIM
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Supported Social Networks and Blogs
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
Wireless Interface
IEEE 802.11a/b/g/n/ac, Bluetooth 4.2
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, magnetometer, gyro sensor
MediaTek
Processor Number
MT6750N
Clock Speed
1.5 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
2 GB
Internal Memory Capacity
16 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 128 GB
Front Camera
Sensor Resolution
8 Megapixel
Lens Aperture
F/2.0
Focus Adjustment
Focus free
Rear Camera
Sensor Resolution
13 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/2.0
Focus Adjustment
Automatic
Light Source
LED flash
Display
LCD display
Diagonal Size
5.2"
Display Format
HD+
Aspect Ratio
18:9
Protection
Connector Type
Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
2990 mAh
USB cable, power adapter, SIM card removal tool
