Nokia 2.3 - 6.2" HD Display - Sand
Quicklinx: FMCNWS00 Mfr#: 719901092091
  • microSDHC
  • Android
Discover the power of AI with Nokia 2.3. It lasts up to 2 days with Adaptive Battery technology, takes epic shots with AI imaging – even in low-light – and unlocks with a glance. Bring great stories to life with the impressive 6.2" HD+ 19:9 screen. Plus, it’s ready for Android 10 and beyond so you can look forward to 2 years of software upgrades and 3 years of monthly security updates.
Be entertained all day
Get lost in your favorite series and movies for longer with the AI-assisted 2-day battery life. And bring great stories to life with the large 6.2" HD+ 19:9 screen.
Designed with you in mind
Nokia 2.3 looks good and feels strong. And with biometric face unlock, its password is as unique as you – one glance, and you’re in.
Ready for Android 10 and beyond
A phone that just keeps getting better. Nokia 2.3 is certified Android One, which means you get a pure software experience with a streamlined interface and no bloatware. Plus, with 2 years of software upgrades and 3 years of monthly security updates, it will stay safe and act as good as new.
A little help wherever you go
The Google Assistant Button is there to keep up with your fast-paced life. Ask questions, see your schedule or check the traffic. Your Assistant learns and adapts with every use – so you can do more with your life, by doing less with your phone.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
BT Mobile
  • Designed with you in mind
    Nokia 2.3 looks good and feels strong. And with biometric face unlock, its password is as unique as you - one glance, and you're in.
  • A little help wherever you go
    The Google Assistant Button is there to keep up with your fast-paced life. Ask questions, see your schedule or cheque the traffic. Your Assistant learns and adapts with every use - so you can do more with your life, by doing less with your phone.
Nokia 2.3 - Android One - sand - 4G smartphone - 32 GB - GSM
4G smartphone
Display
- 6.2" - 19:9
FM radio
MediaTek Helio A22
RAM 2 GB / 32 GB
Supported Memory Card
microSDXC slot - up to 512 GB
Operating System
Android 9.0 Pie
Main Camera
13 Megapixel - f/2.2 - focus: automatic
Second Camera
2 Megapixel - depth sensor
Front Camera
5 Megapixel f/2.4
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
Wi-Fi, Bluetooth
Security Devices
Face recognition
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, Micro-USB
Sand
75.41 mm x 8.68 mm x 157.69 mm
183 g
0.41 W/kg (head) , 1.4 W/kg (body)
Smartphone
Touch
Integrated Components
FM radio
75.41 mm
8.68 mm
157.69 mm
183 g
Body Colour
Sand
Body Material
Polymer, die-cast metal
SAR Value
1.4 W/kg (body), 0.41 W/kg (head)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 9.0 Pie
Intelligent Assistant
Google Assistant
Navigation
GPS, A-GPS, GLONASS, BeiDou
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 5, Band 8
3G UMTS Frequency
2100, 850, 900
4G LTE Band
Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 28, Band 38, Band 40, Band 41
4G LTE Frequency
FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
Wireless Interface
IEEE 802.11b/g/n, Bluetooth 5.0
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor
Security Devices
Face recognition
Additional Features
Face Unlock, Google Assistant Button, 3 years of Security Updates
MediaTek Helio A22
RAM
2 GB
Internal Memory Capacity
32 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 512 GB
Front Camera
Sensor Resolution
5 Megapixel
Lens Aperture
F/2.4
Main Camera
Sensor Resolution
13 Megapixel
Lens Aperture
F/2.2
Focus Adjustment
Automatic
Special Effects
Bokeh effect
Camera Modes
Low-light shots, portrait mode
Light Source
LED flash
Background blur
Second Camera
Sensor Resolution
2 Megapixel
Sensor Type
Depth sensor
Display
Diagonal Size
6.2"
Display Format
HD+
Aspect Ratio
19:9
In-Cell Display Technology
Connector Type
Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
4000 mAh
USB cable, power adapter, SIM card removal tool
