Building on the proven basis of the successful NH-C12P, which received more than 100 awards and recommendations from the international press, the NH-C12P SE14 now comes with Noctua's new NF-P14 140mm fan for further improved quiet cooling performance as well as the new SecuFirm2 multi-socket mounting system. Topped off with Noctua's pro-grade NT-H1 thermal compound and adding support for both LGA1366 and LGA1156, the NH-C12P SE14 is a premium quality quiet cooler that provides lots of airflow for near-socket mainboard components and excellent case compatibility at a height of only 114mm.
Proven six heatpipe design
Recommended by more than 100 international hardware websites and magazines, the NH-C12P heatsink is renowned for its excellent quality and thermal performance.
C-type design with Airflow-Gaps
Due to the down-facing design, two large Airflow-Gaps and the oversize 140mm fan, the NH-C12P SE14 provides superior cooling for near-socket motherboard components.
NF-P14 140mm premium fan
Further improving the original NH-C12Ps much acclaimed quiet cooling performance, the NF-P14 is a highly optimised, premium quality 140mm fan with Vortex-Control Notches for superb quietness and outstanding aerodynamic efficiency.
High compatibility
The down-facing c-type design allows for low height as well as excellent motherboard and case compatibility, making the NH-C12P SE14 suitable for many smaller or desktop style cases.
Noctua's enthusiast grade SecuFirm2 multi-socket mounting provides broad socket compatibility (LGA1366, LGA1156, LGA775, AM2, AM2+ and AM3) and meets the highest demands in safety, performance and ease-of-use.
Noctua NT-H1 high-end thermal compound
Noctua's much-acclaimed NT-H1 is a well proven pro-grade TIM solution that provides minimum thermal resistance, excellent ease-of-use and outstanding reliability.
1.Six heat pipes
2.C-type design with Airflow-Gaps
3.Noctua NF-P14 140mm premium fan
4.Excellent compatibility
5.SecuFirm2™ multi-socket mounting system
6.Noctua NT-H1 high-end thermal compound
7.Socket LGA1366, LGA1156, LGA775, AM3, AM2+, AM2 compatible (backplate required)
