Product
Brand
Noctua NF-A14 PWM 140mm Premium Quality Fan
Quicklinx: 8WDPWS00 Mfr#: NF-A14-PWM
The fully featured NF-A14 PWM is a 140mm fan that is ideal for use on watercooling radiators or as an upgrade for 140mm case fans.
The NF-A14 is a premium quality quiet 140mm fan with a square frame that complies with Noctua's AAO (Advanced Acoustic Optimisation) standard. Its square shape and 140mm mounting holes (124.5mm spacing) make it ideal for use on watercooling radiators or as an upgrade for 140mm case fans. Featuring sophisticated aerodynamic design measures such as Flow Acceleration Channels, the NF-A14 further improves the renowned quiet cooling performance of the award-winning NF-P14.
The PWM version sports Noctua's custom designed NE-FD1 IC for fully automatic speed control via 4-pin fan headers and comes with a Low-Noise-Adaptor to reduce the maximum speed during PWM control from 1500rpm to 1200rpm. Its performance-oriented 1500rpm top speed and comprehensive speed control options make the NF-A14 PWM an elite choice for users who strive to strike a perfect balance between excellent cooling capacity and superb quietness of operation, be it on watercooling radiators, on heatsinks or in case ventilation.
Noctua NF-A14 PWM - case fan
Case fan
Package Content
Low-Noise Adaptor (L.N.A.), Y-Split cable, 4 screws, 4 vibration isolators, 1 extension cable (30 cm)
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
SSO2 bearing
Rotation Speed
300-1500 rpm
Air Flow
82.5 cfm
Noise Level
13.8 - 19.2 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support, Advanced Acoustic Optimisation (AAO), flow acceleration channels
6 years warranty
Case fan
Package Content
Heatsink & Fan
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
SSO2 bearing
Rotation Speed
300-1500 rpm
Air Flow
82.5 cfm
Air Pressure
0.89-1.51 mm
Noise Level
13.8 - 19.2 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.13 A
Power Consumption
1.56 W
Mounting Kit
Included
MTBF
150,000 hour(s)
RoHS
Limited warranty - 6 years
