A Neon Red Joy-Con (L) and Neon Blue Joy-Con (R) together make up a set of Joy-Con controllers. Pick up an extra set of Joy-Con controllers to open new kinds of gaming possibilities!
The right Joy-Con Controller includes an NFC touchpoint to unlock amiibo functionality.
This set includes two neon Joy-Con Controllers (Left and Right) and two black Nintendo Switch Joy-Con Controller Straps.
Release Date: 03 March 2017
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
CNML 048276 Condition: Customer return - item has been used and shows signs of use |
£21.95 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
