NewStar Mobile Flatscreen Floor Stand 27-60" 1 screen
Quicklinx: 9SDCWS00 Mfr#: PLASMA-M1800E
£378.72 ex VAT
£454.46 inc VAT
The NewStar PLASMA-M1800E is a mobile floor stand for LCD/Plasma flatscreens up to 60" (150 cm). With this product on wheels you have perfect flexibility to place the flatscreen where ever you want. A shelf for a notebook or DVD player is included. The height can be adjustment between 110-180 cm. Cables can be placed in the column. Suited for flatscreens between 27-60" with a maximum weight of 50 kg and a maximum VESA hole pattern of 600x450 mm. Perfect for exhibitions, presentation rooms, class rooms and hospital!
Neomounts PLASMA-M1800E cart - for flat panel / AV system - silver
Cart
Adjustable Height
110-180 cm
Tilt
15°
Adjustments
Height, tilt
Recommended Use
Flat panel / AV system
Recommended Display Size
27"-70"
VESA Mounting Interface
From 200 x 200 mm, up to 600 x 450 mm
Max Load Weight
50 kg
Silver
Wheels Qty
4
5-year warranty
Adjustable Height
110-180 cm
Silver
AV Furniture
Cart
Recommended Use
Shelf Qty
1
Cable Management
Integrated cable management
27"-70"
Tilt
15°
Adjustments
Height, tilt
Max Load Weight
50 kg
Wheels Qty
4
Adjustable height, wheels
Limited warranty - 5 years
