NewStar Generic Newstar Flatscreen Desk Mount 10-26" Clamp 1 Screen
Reduced Price - Whilst Stocks Last!
Quicklinx: 9YBBWS00 Mfr#: FPMA-D960
20 in stock
£59.95 ex VAT
£71.94 inc VAT
The NewStar desk mount FPMA-D960 allows you to attach a LCD/TFT screen up to 26" on a desk. With this mount you can easily swivel, tilt and rotate the monitor. It has 3 pivots. The height adjustment of 45 cm can be changed manually. The desk mount can hold screens up to 12 kg and is attached on a desk by a clamp. The arm length is 43 cm. This model is suited for all LCD/TFT screens with a VESA 75x75 or 100x100 mm hole pattern. By using an ergonomic monitor arm you prevent neck- and back complaints. Ideal for use in offices and on counters or receptions.
NewStar Full Motion Desk Mount (clamp) for 10-30" Monitor Screen, Height Adjustable - Black - desk mount (adjustable arm)
Desk mount (adjustable arm)
Adjustable Depth
10-43 cm
Adjustable Height
0-45 cm
Tilt
180°
Pan
180°
Rotation
360°
Recommended Use
LCD display
Recommended Display Size
10"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
5-year warranty
Adjustable Depth
10-43 cm
Adjustable Height
0-45 cm
AV Furniture
Desk mount
Design
Adjustable arm
Recommended Use
LCD display
Cable Management
Integrated cable management
10"-30"
Tilt
180°
Pan
180°
Rotation
360°
Max Load Weight
10 kg
Adjustable height, adjustable depth, rotating, swivel adjustment
Limited warranty - 5 years
Brand: NewStar
Price Range Ex VAT: 50 - 100
