The NewStar desk mount, model FPMA-D960DG is a tilt-, swivel and rotatable desk mount for 2 flat screens up to 26". This mount is a great choice for space saving placement on desks using a grommet mount.
NewStars' unique tilt (180°), rotate (360°) and swivel (180°) technology allows the mount to change to any viewing angle to fully benefit from the capabilities of the flat screen. The mount is manually height adjustable from 0 to 45 centimeters. A unique cable management conceals and routes cables from mount to flat screen. Hide your cables to keep the workplace nice and tidy. NewStar FPMA-D960DG has three pivot points and is suitable for screens up to 26" (65 cm).
- Neomounts FPMA-D960DG mounting kit - full-motion - for 2 LCD displays - black
- Product Type
- Mounting kit (full-motion) - grommet, desk-mountable
- Adjustable Depth
- 10-43 cm
- Adjustable Height
- 0-45 cm
- Tilt
- 180°
- Rotation
- 360°
- Swivel
- 180°
- Adjustments
- Height, tilt, swivel, rotation, depth
- Recommended Use
- 2 LCD displays
- Recommended Display Size
- 10"-27"
- VESA Mounting Interface
- Up to 100 x 100 mm, from 75 x 75 mm
- Max Load Weight
- 16 kg
- Black
- 5-year warranty
- Adjustable Depth
- 10-43 cm
- Adjustable Height
- 0-45 cm
- Black
AV Furniture
- Mounting kit
- Design
- Full-motion
- Recommended Use
- 2 LCD displays
- Placing / Mounting
- Grommet, desk-mountable
- Cable Management
- Integrated cable management
- 10"-27"
- Tilt
- 180°
- Rotation
- 360°
- Swivel
- 180°
- Adjustments
- Max Load Weight
- 16 kg
- Rotating, swivel adjustment
- Limited warranty - 5 years
