The NEWLink Micro USB KVM CPU with attached cables allows users to access two USB enabled computers from one USB Keyboard, USB Mouse and SVGA Monitor. Two cables (1x 1.8Mtr/6ft and 1x 0.6Mtr/2ft) are supplied molded to the switch. No interface card or software is needed, installation is as easy as connecting cables from the CPU Switch to your computers.
The Micro USB KVM Switch is independent of computer operating systems.
Operation is as simple as entering hot-key commands from a keyboard.
- NEWLink Micro 2 Port USB KVM with Built in USB Cables - KVM switch - 2 ports - desktop
- KVM switch - 2 ports - USB
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM port(s)
- KVM Users Qty
- 1 local user
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1440
- 2 x keyboard (USB) / mouse (USB) - Type A , 2 x VGA - HD-15 , 1 x VGA - HD-15
- Cables Included
- 1 x keyboard / mouse / video cable - 1.8 m , 1 x keyboard / mouse / video cable - 60 cm
- DDC
