NetGear WND930 Dual Band High Power 802.11n Outdoor Access P
Quicklinx: B63KWS00 Mfr#: WND930-10000S
Type: Radio access point
Connectivity: Wired, Wireless
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 3 more
Compatibility: PC
  • IEEE 802.11n (draft 2.0)
£543.06 ex VAT
£651.67 inc VAT
The WND930 Outdoor Access Point is a dual band concurrent 802.11n Outdoor Access Point that combines high power, optimal high gain antennas, and an industrial grade enclosure for optimal outdoor deployment. The WND930 Outdoor Access Point is powered by redundant dual Power over Ethernet (PoE) gigabit ports as well as the capability to power other PoE devices. The WND930 Outdoor Access Point operates under harsh environment with its industrial grade IP-67 enclosure and an embedded heater to allow the Access Point to operate in below freezing point temperature.
The WND930 Outdoor Access Point is ideal for hotels, resorts, schools, multi-dwelling apartments, and other locations needing high throughput, high capacity outdoor coverages. The WND930 Outdoor Access Point can operate either as a point-to -point mesh link between remote locations or as an Access Point providing coverages for users. As with all NETGEAR wireless products, the WND930 Outdoor Access Point is designed with an easy setup for a reliable, high performance and affordable total cost of ownership.
  • High powered for super coverage
    Up to 500 mW of RF output power combine with high gain (8 dBi) dual band internal antenna to maximize coverage. High receive sensitivity (up to -90 dBm) to optimally balance uplink and downlink.
  • Industrial grade enclosure to operate in harsh environment
    Ingress Protection marking of IP-67 rated to operate in extreme environment. Embedded heater automatically activates to allow proper operation in below freezing temperature.
  • Flexible Power over Ethernet choices to maximize redundancy and deployment options
    Dual gigabit Ethernet ports with redundancy to enable AP to continue to operate in the case of intermittent power failure. PoE power sourcing (PSE) to power other PoE devices such as surveillance cameras directly from the WND930 Outdoor Access Point.
  • Flexible deployment options for a variety of applications
    Flexible deployment models including point to point mesh with embedded high gain directional antenna and access point mode with external antenna option. Robust wall mounting and pole mounting kits for flexible deployment options.
NETGEAR WND930 - radio access point
Radio access point
External - outdoor
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz, 5 GHz
Pole mount, mounting brackets
Power Over Ethernet (PoE) Supported
PoE
22.5 cm x 25.5 cm x 7.8 cm
1.894 kg
Radio access point
Ruggedized Design
Outdoor
22.5 cm
25.5 cm
7.8 cm
1.894 kg
External
Wireless, wired
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, active
Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS)
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
Authentication Method
Basic Service Set Identifier (BSSID)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at
2 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T (PoE) - RJ-45 , 4 x aerial - N connector
IP67
PoE
-20 °C
60 °C
10 - 90%
B63K C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
B63K C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
B63K C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.04
B63K C2G 2m Cat6a Shielded Patch - Blue In Stock £7.40
Connectivity: Wired
Connectivity: Wireless
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11a
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n (draft 2.0)
Compatibility: PC
Brand: NETGEAR
Price Range Ex VAT: 500 - 750
