Connect your Windows®-based notebook or desktop computer to a Wireless-N network for applications such as online gaming and a secure and reliable connection to the Internet.
The NETGEAR N300 Wireless USB Adapter connects your Windows®-based notebook or desktop computer to a Wireless-N network for faster downloads, voice and music, and online gaming. Easy setup with the NETGEAR® genie® gets you up and running fast, while Push `N' Connect gives you a secured connection at the push of a button. Compatibility with Wireless-G networks allows hassle-free connection flexibility.
Provides Wireless-N speed for simultaneous downloads, voice and music
Backward compatible with Wireless-G
Desktop dock provides option for better desktop placement
Easy setup with NETGEAR genie
Push `N' Connect offers a secured wireless Internet connection at the push of a button
Expert technical support team available 24/7
Works with any standard WiFi Router or Modem Router/Gateway like Belkin®, Linksys®, D-Link®, NETGEAR®, & others
N300 Wi-Fi
Get faster downloads & Internet gaming. -
Wi-Fi range
The product is suitable for small to medium homes. -
Ease of use with Push 'N' Connect
Easily push the button for Wi-Fi connections (WPS). -
Easy to install
The product includes NETGEAR genie software on a CD for simple installation.
- NETGEAR WNA3100 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 7.8 cm x 2.4 cm x 0.9 cm
- 18 g
- Localisation
- Europe
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup
- System Requirements
- Microsoft Windows Vista / XP / 7
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Localisation
- Europe
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Spread Spectrum Method
- OFDM
- 300 Mbps
- Line Coding Format
- CCK
- Frequency Band
- 2.4 GHz
- WPS, Push ‘N’ Connect button
Aerial
- Antenna
- Internal
- Antenna Qty
- 1
- Connections
- 1 x USB - 4 pin USB Type A
- Included Accessories
- USB cradle
- Cables Included
- 1 x USB cable (external)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- FCC
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows XP/Vista/7 - Pentium - 300 MHz
- 7.8 cm
- 2.4 cm
- 0.9 cm
- 18 g
- Limited warranty - 1 year
- 0 °C
- 45 °C
