Your basket is empty
NetGear WNA3100-100PES N300 Wireless USB Adaptor
Quicklinx: B82RWS00 Mfr#: WNA3100-100PES
  • IEEE 802.11n
Connect your Windows®-based notebook or desktop computer to a Wireless-N network for applications such as online gaming and a secure and reliable connection to the Internet.
The NETGEAR N300 Wireless USB Adapter connects your Windows®-based notebook or desktop computer to a Wireless-N network for faster downloads, voice and music, and online gaming. Easy setup with the NETGEAR® genie® gets you up and running fast, while Push `N' Connect gives you a secured connection at the push of a button. Compatibility with Wireless-G networks allows hassle-free connection flexibility.
Provides Wireless-N speed for simultaneous downloads, voice and music
Backward compatible with Wireless-G
Desktop dock provides option for better desktop placement
Easy setup with NETGEAR genie
Push `N' Connect offers a secured wireless Internet connection at the push of a button
Expert technical support team available 24/7
Works with any standard WiFi Router or Modem Router/Gateway like Belkin®, Linksys®, D-Link®, NETGEAR®, & others
NETGEAR WNA3100 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
7.8 cm x 2.4 cm x 0.9 cm
18 g
Europe
802.11b, 802.11g, 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup
Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
1 year warranty
Network adapter
External
USB 2.0
Europe
Wireless
Spread Spectrum Method
OFDM
Data Transfer Rate
300 Mbps
Line Coding Format
CCK
Frequency Band
2.4 GHz
Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button
Aerial
Antenna
Internal
Antenna Qty
1
1 x USB - 4 pin USB Type A
USB cradle
1 x USB cable (external)
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
FCC
Software Included
Drivers & Utilities
System Requirements Details
Windows XP/Vista/7 - Pentium - 300 MHz
7.8 cm
2.4 cm
0.9 cm
18 g
Limited warranty - 1 year
45 °C
