NetGear WNA1000M-100PES N150 Wireless USB Micro Adapter
Quicklinx: B82QWS00 Mfr#: WNA1000M-100PES
  • IEEE 802.11n
Tiny Device. Big Results.
You have a wired laptop, but you want wireless connectivity. This tiny Wireless USB Micro Adapter gives you that ability. It's a compact way to take a Windows®-based laptop on the road and connect to WiFi hotspots or move around the house while emailing and surfing online.
The NETGEAR G54/N150 Wireless USB Micro Adapter is perfect to connect your Windows®-based laptop to WiFi hotspots while on the go. The innovative micro-design is compatible with the latest in wireless connectivity and the tiny size makes it hardly noticeable when plugged into a laptop's USB port. Easy setup with the NETGEAR® genie® gets you up and running fast, while Push `N' Connect gives you a secured connection at the push of a button.
Perfect for mobility -- Ultra small Wireless-N USB adapter fits neatly into laptop's USB port
Surf, email, chat -- Wireless-N connection for basic Internet applications
Connect to a Wireless-G or Wireless-N network
Easy setup with NETGEAR genie
Push `N' Connect offers a secured wireless Internet connection at the push of a button
Works with any standard WiFi Router or Modem Router/Gateway like Belkin®, Linksys®, D-Link®, NETGEAR®, & others
NETGEAR WNA1000M - network adapter - USB
Network adapter
External
Interface (Bus) Type
USB
2 cm x 1.5 cm x 0.7 cm
2 g
Europe
802.11b/g/n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Microsoft Certification
Compatible with Windows 7
Network adapter
External
USB
Europe
Wireless
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
Push ‘N’ Connect button
1 x USB - 4 pin USB Type A
Software Included
Drivers & Utilities
System Requirements Details
Windows XP/Vista/7 - Pentium
2 cm
1.5 cm
0.7 cm
2 g
