NetGear WN3000RP-200UKS 300Mbps Universal Wi-Fi Range Extender
Quicklinx: 9ZP0WS00 Mfr#: WN3000RP-200UKS
Type: Wi-Fi range extender
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: Mac, PC
  • IEEE 802.11n
£17.49 ex VAT
£20.98 inc VAT
Turn Dead Zones Into Connected Corners - N300 WiFi Range Extender
The NETGEAR Universal WiFi Range Extender effectively doubles the operating distance of your entire wireless network and conveniently avoids additional need for power cables or device clutter on your office desk or home theater.
WN3000RP extends your wireless network to include the area outside the range of your existing wireless router by overcoming obstacles and enhancing overall network signal quality, giving you the freedom to roam anywhere in the house and access Internet without worrying about coverage. The product was specifically designed to be plugged into an electrical outlet, and blends in nicely with any surrounding. It is compatible with wireless b/g/n routers, gateways and Internet service provider devices.
This device extends wireless coverage with universal compatibility, easy install (no CD required) and allows you to connect iPads, Smartphones, and many more devices seemlessly. Move around with your mobile devices and keep them connected by giving your existing WiFi a boost. This small, easy-to-install wall-plug WiFi range extender also creates new WiFi connectivity for up to 1 wired device like a Smart TV, Blu-ray player or game console.
Improve range and speed of your existing N300 WiFi network throughout your home for wireless devices like iPads, iPods, laptops, smart phones, game consoles and TVs.
Fast Ethernet Port
Connect a wired device like a Blu-ray player, game console, smart TV or streaming player to your WiFi network.
External Antennas
For better WiFi coverage and more speed.
Push N' Connect
Push
N' Connect using Wi-Fi Protected Setup (WPS) connects computers and/or routers to the Extender quickly and securely.
  • Boost N300 Wi-Fi
    Improve range and speed of your existing N300 Wi-Fi network throughout your home for wireless devices like iPads, iPods, laptops, smart phones, game consoles and TVs.
  • Fast Ethernet port
    Connect a wired device like a Blu-ray player, game console, smart TV or streaming player to your Wi-Fi network.
  • External antennas
    For better Wi-Fi coverage and more speed.
  • Push 'N' Connect
    Push 'N' Connect using Wi-Fi protected setup (WPS) connects computers and/or routers to the extender quickly and securely.
  • Smart LED indicators
    Finds best location for optimal Wi-Fi coverage.
  • Compatible
    Works with any wireless b/g/n router or gateway from NETGEAR and other brands.
NETGEAR WN3000RPv2 - Wi-Fi range extender
External
United Kingdom
Frequency Band
2.4 GHz
6.7 cm x 5.5 cm x 3.4 cm
98 g
6.7 cm
5.5 cm
3.4 cm
98 g
United Kingdom
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Repeating mode, Wi-Fi Protected Setup (WPS), wireless bridge mode, Push ‘N’ Connect button
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
Antenna
External detachable
Antenna Qty
2
1 x 100Base-TX - RJ-45
Internal power supply
9ZP0 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
9ZP0 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
9ZP0 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.02
Speed: 300Mbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: NETGEAR
Price Range Ex VAT: 0 - 50
