The NETGEAR ProSAFE WC7600 Premium Wireless Controller is a fully featured enterprise class, high performance and secured wireless controller capable of managing up to 150 Access Points and 6,000 concurrent clients per cluster. The WC7600 delivers ultra-fast Access Point discovery, Layer 2 and Layer 3 fast roaming, multiple 10 Gigabit connectivity, a captive portal for guest access, fully distributed architecture, and ease of configuration and management.
Unlike other Wireless systems that are costly, complex and cumbersome to deploy, the WC7600 wireless controller is ideal for K-12 education, hospitality, and healthcare deployments. Designed with simplicity in mind for management and ease of use, it offers enterprise grade functionality and capability for small to mid-sized organizations, without the cost and complexity of big IT.
- NETGEAR WC7600 Premium Wireless Controller - network management device
- Network management device
- Form Factor
- External - 1U
- Localisation
- United Kingdom
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
- Power
- AC 100/230 V
- Power Redundancy
- 44 cm x 43 cm x 4.3 cm
- 7.57 kg
- NETGEAR lifetime warranty
- Height (Rack Units)
- 1U
- 44 cm
- 43 cm
- 4.3 cm
- 7.57 kg
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wired
- Remote Management Protocol
- SNMP 1, SNMP 2
- Status Indicators
- Status, link/activity, fan
- Auto-sensing per device, auto-negotiation, load balancing, stackable, IPv6 support, Wi-Fi Multimedia (WMM) support, RADIUS support, DHCP server, IPv4 support, rogue access point detection
- Encryption Algorithm
- AES, TKIP, WPA, WPA2, WEP
- Authentication Method
- Radio Service Set ID (SSID), LDAP, Active Directory
- IEEE 802.1x, IEEE 802.11i, IEEE 802.11e
- 2 x 10Gb Ethernet - SFP+ , 1 x 1000Base-T (management) - RJ-45 , 1 x management - DB-9 , 1 x USB 2.0 - Type A
- MTBF
- 664,072 hours
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- AC 100/230 V
- 165 Watt
- 0 °C
- 45 °C
- 10 - 90%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
