NETGEAR Premium Business 802.11ac 4 x 4 Wave 2 Wireless Access Point, purposely designed for enterprises requiring high density and superior performance
The NETGEAR Premium Business 802.11ac 4 x 4 Wave 2 Wireless Access Point (AP) delivers high performance with maximum client density for enterprises requiring ubiquitous and reliable wireless for all business applications. The WAC740 is a controller managed Access Point with ease of centralized management with all NETGEAR wireless controllers from small (WC7500) to mid-size (WC7600) and large-size (WC9500) deployment. The WAC740 operates with Multi-User MIMO and can achieve speeds up to 600 Mbps for 2.4 GHz and 1.7 Gbps at 5 GHz. The WAC740 comes with 2 Power over Ethernet (PoE) ports, including one port that can handle up to 2.5 Gbps of throughput, enabling a single wire to connect to 2.5 Gbps capable switch for ease of wiring installation.
- ProSAFE 802.11ac AP Wave 2 provides a theoretical connection rate of up to 2.6Gbps per radio—roughly double the rates offered by today’s high-end 802.11ac access points
- Reliable wireless coverage with 4 streams of data based on 4x4 (Transmit and Receive) optimized internal antennas
- Multi-user MIMO (MU-MIMO) increases efficiency and capacity – enabling clients to utilize the RF spectrum much more efficiently by allowing multiple-AP-to client transmissions, beamforming, wider bandwidth, and improved encoding
- AirQual feature enables spectrum analysis and interference identification
- Centrally managed by ProSAFE Wireless Controllers
- 2.5GBASE-T Multi-Gigabit support eliminates bottlenecks associated with standard Gigabit Ethernet (NBASE-T switch required to obtain speeds higher than 1Gbps w/ a single port)
- NETGEAR WAC740 4 x 4 - radio access point
- Radio access point
- Form Factor
- External
- Localisation
- Worldwide (excluding United States and Canada)
- Data Link Protocol
- IEEE 802.11ac Wave 2
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Aggregate throughput: 1 Gbps
- Included Accessories
- Wall mounting kit, ceiling mounting kit
- Power Over Ethernet (PoE) Supported
- PoE
- 19.7 cm x 19.7 cm x 4 cm
- 726 g
- NETGEAR lifetime warranty
- 19.7 cm
- 19.7 cm
- 4 cm
- 726 g
- Localisation
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1700 Mbps
- Bonjour
- Remote Management Protocol
- Telnet, SSH
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Status Indicators
- Power, LAN, link/activity
- Auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, wireless bridge mode, bandwidth control, rogue access point detection, Transmit Power Control (TPC), band steering, Static Link Aggregation
- Encryption Algorithm
- SSL, TLS, PEAP, TTLS, WPA, WPA2
- Authentication Method
- Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3af, IEEE 802.1x, IEEE 802.11i, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac Wave 2
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- Gain Level
- 6 dBi
- 1 x 2500Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45 , 4 x aerial - SMA , 1 x console - RJ-45
- Cables Included
- 1 x network cable
- PoE
- Limited warranty - parts - lifetime
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
