NETGEAR WAC740 2 Port Premium Access Point
Quicklinx: CF11WS00 Mfr#: WAC740-10000S
Type: Radio access point
Standards: IEEE 802.11ac Wave 2
Speed: 1700Mbps
Rackmount or External: External
10 in stock
£322.11 ex VAT
£386.53 inc VAT
NETGEAR Premium Business 802.11ac 4 x 4 Wave 2 Wireless Access Point, purposely designed for enterprises requiring high density and superior performance
The NETGEAR Premium Business 802.11ac 4 x 4 Wave 2 Wireless Access Point (AP) delivers high performance with maximum client density for enterprises requiring ubiquitous and reliable wireless for all business applications. The WAC740 is a controller managed Access Point with ease of centralized management with all NETGEAR wireless controllers from small (WC7500) to mid-size (WC7600) and large-size (WC9500) deployment. The WAC740 operates with Multi-User MIMO and can achieve speeds up to 600 Mbps for 2.4 GHz and 1.7 Gbps at 5 GHz. The WAC740 comes with 2 Power over Ethernet (PoE) ports, including one port that can handle up to 2.5 Gbps of throughput, enabling a single wire to connect to 2.5 Gbps capable switch for ease of wiring installation.
  • ProSAFE 802.11ac AP Wave 2 provides a theoretical connection rate of up to 2.6Gbps per radio—roughly double the rates offered by today’s high-end 802.11ac access points
  • Reliable wireless coverage with 4 streams of data based on 4x4 (Transmit and Receive) optimized internal antennas
  • Multi-user MIMO (MU-MIMO) increases efficiency and capacity – enabling clients to utilize the RF spectrum much more efficiently by allowing multiple-AP-to client transmissions, beamforming, wider bandwidth, and improved encoding
  • AirQual feature enables spectrum analysis and interference identification
  • Centrally managed by ProSAFE Wireless Controllers
  • 2.5GBASE-T Multi-Gigabit support eliminates bottlenecks associated with standard Gigabit Ethernet (NBASE-T switch required to obtain speeds higher than 1Gbps w/ a single port)
NETGEAR ProSafe WAC740 4 x 4 - radio access point
Radio access point
External
Worldwide (excluding United States and Canada)
Frequency Band
2.4 GHz, 5 GHz
Performance
Aggregate throughput: 1 Gbps
Wall mounting kit, ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE
19.7 cm x 19.7 cm x 4 cm
726 g
NETGEAR lifetime warranty
Radio access point
19.7 cm
19.7 cm
4 cm
726 g
External
Wireless
Data Transfer Rate
1700 Mbps
Network / Transport Protocol
Bonjour
Remote Management Protocol
Telnet, SSH
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Power, LAN, link/activity
Auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, wireless bridge mode, bandwidth control, rogue access point detection, Transmit Power Control (TPC), band steering, Static Link Aggregation
Encryption Algorithm
SSL, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID)
IEEE 802.3af, IEEE 802.1x, IEEE 802.11i, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
Antenna Qty
4
Gain Level
6 dBi
1 x 2500Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45 , 4 x aerial - SMA , 1 x console - RJ-45
1 x network cable
PoE
Limited warranty - parts - lifetime
CF11 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
CF11 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
CF11 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.20
CF11 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.49
Speed: 1700Mbps
Brand: NETGEAR
Price Range Ex VAT: 300 - 500
