NETGEAR WAC720 ProSAFE Business 2 x 2 Dual Band Wireless-AC Access P
Quicklinx: CHLYWS00 Mfr#: WAC720B03-10000S
Type: Radio access point
Connectivity: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
Compatibility: PC
  • IEEE 802.11n
£378.94 ex VAT
£454.72 inc VAT
The NETGEAR 3 AP pack of WAC720 ProSAFE Wireless Access Point is a high-performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.2 Gbps (300 Mbps for 2.4GHz and 867 Mbps 802.11ac for 5GHz) with standalone and Ensemble management for centralized group management of up to 10 APs. WAC720 Business AP operates in either standalone mode with an intuitive user interface or in Ensemble mode for centralized group management of up to 10 APs. It is perfectly positioned for customers demanding high throughput, ultra-superior performance, and extensive coverage deployment for Small and Medium Enterprises, K-12, and Hospitalities.
NETGEAR Business 2 x 2 Dual Band Wireless-AC Access Point WAC720 - radio access point
Radio access point
Packaged Quantity
3 (specifications are for single item)
External
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Aggregate throughput: 1.2 Gbps , Maximum throughput (2.4 GHz): 300 Mbps , Maximum throughput (5 GHz): 867 Mbps
Wall mounting kit, ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE
19.7 cm x 19.7 cm x 4 cm
726 g
NETGEAR lifetime warranty
Packaged Quantity
Radio access point
19.7 cm
19.7 cm
4 cm
726 g
External
Wired
Network / Transport Protocol
Bonjour
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Power, LAN, wireless, link/activity
VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode, 2T2R MIMO technology, LLDP support, 802.1x authentication, Transmit Power Control (TPC)
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
External detachable and internal
1 x console - RJ-45 , 1 x 1000Base-T (PoE) - RJ-45 , 2 x aerial - RP-SMA
1 x network cable
PoE
Limited warranty - lifetime
Connectivity: Wired
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: NETGEAR
Price Range Ex VAT: 300 - 500
