NetGear WAC120 AC1200 Simultaneous Dual-Band WiFi Access Point
Quicklinx: 9TPPWS00 Mfr#: WAC120-100UKS
  • IEEE 802.11n (draft 2.0)
Superior 802.11ac performance with an affordable price point
The NETGEAR WAC120 Wireless Access Point is a cost effective, high performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.2 Gbps (300 Mbps for 2.4 GHz and 867 Mbps 802.11ac for 5 GHz). WAC120 802.11ac AP operates in standalone mode with an intuitive user interface and a flexible desktop mounting stand. It is perfectly positioned for customers demanding high throughput, ultra superior performance, and extensive coverage deployment for Small and Home Office environments.
High performance dual band 802.11ac wireless access point
Deliver the cost effective solution for Small Office and Home Office
Industry leading performance and value with 1.2 Gbps of wireless throughput
NETGEAR reliable 3 year product warranty
Flexible deployment with simplicity in management
Small offices with a single WAC120 to provide maximum throughput for the entire premise
Dental offices with a few WAC120 to provide ubiquitous coverage with strong receptions
Small hospitalities such as Bed and Breakfast for ease of setup and reliable connectivity
Gigabit Wireless Connectivity for Small Office and Home Office
Support up to 1.2 Gbps (867 Mbps at 5 GHz and 300 Mbps at 2.4 GHz) of wireless throughput
Gigabit wired connectivity to Internet gateway routers or cable modems
Dual band concurrent operation at both 2.4 and 5 GHz frequency range
Simple connectivity and ease of set up
Connect simply to DSL gateway, routers, or cable modems
WAC120 802.11ac Access Point provides high performance gigabit wireless
Wireless Protected Setup (WPS) button enables ease of client auto configuration
NETGEAR WAC120 - radio access point
Radio access point
External
United Kingdom
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0), IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
17 cm x 18 cm x 6 cm
322 g
3 years warranty
Radio access point
17 cm
18 cm
6 cm
322 g
United Kingdom
External
Wireless
Data Transfer Rate
1.2 Gbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, status, LAN, wireless
Auto-uplink (auto MDI/MDI-X), MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), Wireless Client Mode
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
Authentication Method
Basic Service Set Identifier (BSSID)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
Internal
Gain Level
2 dBi
1 x 1000Base-T - RJ-45
1 x network cable
External power adapter
Limited warranty - 3 years
10 - 90%
9TPP C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
9TPP C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
9TPP C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.58
9TPP C2G 2m Cat6a Shielded Patch - Blue In Stock £7.11
