Your basket is empty
NetGear Universal WiFi Range Extender
Quicklinx: 7VJLWS00 Mfr#: WN2000RPT-100UKS
  • IEEE 802.11n
N300 WiFi Range Extender boosts your existing WiFi home coverage and allows you to connect up to 4 wired devices like Smart TVs, gaming consoles to your wireless network. It works with any standard router or gateway and enables a better WiFi connection for laptops, home theater devices, smartphones and more.
Boost N300 WiFi -- Improve range and speed of your existing N300 WiFi network.
4 Fast Ethernet Ports -- Connect up to 4 wired devices like Blu-ray, players, game consoles, smart TVs or streaming players to your WiFi network.
It's Easy -- Easy installation using any web browser on laptops, PC's or tablets. No CD required.
NETGEAR WN2000RPT Universal WiFi Range Extender - Wi-Fi range extender
External
United Kingdom
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Vertical stand
17.8 cm x 13 cm x 3.5 cm
0.68 kg
17.8 cm
13 cm
3.5 cm
0.68 kg
United Kingdom
External
Wireless
Frequency Band
2.4 GHz
Status Indicators
Status
Wi-Fi Protected Setup (WPS), wireless bridge mode
Encryption Algorithm
WPA-PSK, WPA2-PSK
4 x 100Base-TX - RJ-45
Vertical stand
External power adapter
7VJL C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.09
7VJL C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.55
7VJL C2G 2m Cat6a Shielded Patch - Blue In Stock £6.53
7VJL C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.38
