This GBIC is built to insert into any one of the two built-in 10 GE SFP+ interfaces of GSM7328Sv2 and GSM7352Sv2, and into the 10GE SFP+ interface of AX743 adapter module for GSM73xxS/GSM73xxSv2. Once inserted (hot-swappable), the AXM761 10GBASE-LR SFP+ (LC connector) drives 10 Gigabit Ethernet up to 10 km distances with 9/125µm SMF single mode fiber cables, or up to 33 m distances with 62.5/125µm OM1 multimode fiber cables.
This is a pack of 10 AXM762 SFP+ modules.
- NETGEAR ProSafe AXM762 - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC single-mode
- Packaged Quantity
- 10 (specifications are for single item)
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 300 m
- 1.37 cm x 5.57 cm x 1.19 cm
- 19.2 g
- 5-year warranty
- Packaged Quantity
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LR
- 10GbE
- 10 Gbps
- 1310 nm
- 300 m
- IEEE 802.3ae
- 1 x Ethernet 10GBase-LR - LC single-mode x 2
- Compatible Slots
- 1 x SFP+
- MTBF
- 4,986,536 hours
- UL 1950, CSA 22.2 No. 950, RoHS
- 1.37 cm
- 5.57 cm
- 1.19 cm
- 19.2 g
- Limited warranty - 5 years
- 0 °C
- 70 °C
