The ProSAFE S3300 52PT Gigabit Stackable Smart Switch is a L2+ web based platform : PoE+ in a 48 port configuration. 4 dedicated 10G ports are included as standard (2 x 10GBase-T and 2 x SFP+) for stacking and/or uplinks to aggregation layers or storage and server connections. PoE/PoE+ support between 190W up to 1,440W with RPS (model dependent).
- NETGEAR S3300-52X-PoE+ - switch - 52 ports - smart - rack-mountable
- Switch - 52 ports - smart - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (PoE+) + 2 x 10Gb Ethernet + 2 x 10Gb Ethernet SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 390 W
- Performance
- Bandwidth: 176 Gbps
- Capacity
- VLANs supported: 256 , ACL entries: 100 , IPv4 routes (static): 32 , DHCP snooping entries: 8000 , ARP entries: 512 , Forwarding table entries (Multicast): 512 , Priority queues per port: 8
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- Static IPv4 routing
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP, CLI
- Flow control, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, ALG support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Weighted Random Early Detection (WRED), Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), DHCP client, Energy Efficient Ethernet, dual firmware images, Strict Priority Queuing (SPQ), Class of Service (CoS), IP source guard
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az, IEEE 802.1Qat, IEEE 802.1Qav, IEEE 802.1BA
- Power
- AC 100/230 V (50/60 Hz)
- 44 cm x 34.5 cm x 4.3 cm
- 5.54 kg
- Localisation
- Latin America, North America, Europe
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 390 W
- Performance
- Capacity
- 16K entries
- 9KB
- Max Units In A Stack
- 6
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+
- Processor
- : 800 MHz
- RAM
- 512 MB
- Flash Memory
- 128 MB
- 48 x 1000Base-T RJ-45 PoE+ , 2 x 10GBase-T RJ-45 uplink/stacking , 2 x 10Gbit LAN SFP+ uplink/stacking , 1 x USB 2.0 Type A
- Power Device
- Internal power supply
- Voltage Required
- 1484.12 Watt
- Redundant Power System (RPS) connector
- Rack Mounting Kit
- Included
- MTBF
- 216,809 hours
- CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, CCC, RoHS, FCC Part 15 A, C-Tick Class A, VCCI Class A
- Localisation
- 44 cm
- 34.5 cm
- 4.3 cm
- 5.54 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £2.27 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.18 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £7.05 |
