Product
NetGear S3300 28-port Stackable POE Smart Switch W/10G
Quicklinx: B2F6WS00 Mfr#: GS728TXP-100NES
Type: Gigabit Ethernet
Ports: 28
Data Transfer Rate: 10Gbps
Managed: Yes
POE: PoE+
£797.60 ex VAT
£957.12 inc VAT
The ProSAFE S3300 Switch series is a new generation of Gigabit Stackable Smart Switches, inclusive of 4 dedicated 10G ports for uplinks and/or stacking between other S3300 switches. As SMBs produce and consume more data, Gigabit to the desktop increasingly needs to be underpinned with 10GbE connectivity to the core to ensure a consistent, seamless user experience. This new generation of switches provides SMB customers with the most cost-effective 10G connections between their Gigabit access layer switches and aggregation layer 10G switches and Routers. The ProSAFE S3300 Smart Series is the blueprint for a dependable future-proof network. From Greenfield network requirements to network refresh projects, the series sets new standards in defining flexibility and choice for SMBs looking to leverage reliable, future proof technologies at affordable price points.
NETGEAR ProSAFE S3300-28X-PoE+ - switch - 28 ports - smart - rack-mountable
Switch - 28 ports - smart - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 2 x 10Gb Ethernet + 2 x 10Gb Ethernet SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
195 W
Performance
Bandwidth: 128 Gbps
VLANs supported: 256 , ACL entries: 100 , IPv4 routes (static): 32 , DHCP snooping entries: 8000 , ARP entries: 512 , Forwarding table entries (Multicast): 512 , Priority queues per port: 8
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP, CLI
Flow control, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, ALG support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Weighted Random Early Detection (WRED), Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), DHCP client, Energy Efficient Ethernet, dual firmware images, Strict Priority Queuing (SPQ), Class of Service (CoS), IP source guard
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az, IEEE 802.1Qat, IEEE 802.1Qav, IEEE 802.1BA
AC 100/230 V (50/60 Hz)
44 cm x 25.7 cm x 4.3 cm
3.77 kg
Latin America, North America, Europe
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
195 W
Performance
Bandwidth: 128 Gbps
16K entries
Jumbo Frame Support
9KB
Max Units In A Stack
6
Routing Protocol
Static IPv4 routing
Authentication Method
RADIUS, TACACS+
: 800 MHz
RAM
512 MB
Flash Memory
128 MB
24 x 1000Base-T RJ-45 PoE+ , 2 x 10GBase-T RJ-45 uplink/stacking , 2 x 10Gbit LAN SFP+ uplink/stacking , 1 x USB 2.0 Type A
Internal power supply
748.18 Watt
Rack Mounting Kit
Included
MTBF
147,965 hours
CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, CCC, RoHS, FCC Part 15 A, C-Tick Class A, VCCI Class A
44 cm
25.7 cm
4.3 cm
3.77 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
B2F6 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
B2F6 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.35
B2F6 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.02
Ports: 28
Managed: Yes
POE: PoE+
Brand: NETGEAR
Price Range Ex VAT: 750 - 1000
