EPS mode: provide 4 additional PSU slots to M6100-3S chassis
M6100-3S power management system can use the four additional APS1000W PSUs transparently.
Reliable
Highly reliable solution due to non-stop switching, non-stop routing and hitless failover at both fabric and management levels. N + 1 redundancy for power supplies and loop-free, non-stop multi-chassis and Link Aggregation (MLAG). -
High-speed performance
1.4 Tbps of total routing/switching capacity and up to 1,071 Mpps of intra-blade throughput. 480 Gbps distributed fabric between modules, each slot provides 2 passive 40G backplane accesses. -
Increased flexibility
Distributed fabric to eliminate modules dedicated to passive backplane, redundant fabric and management. Each I/O blade with distributed fabric makes it easy to manage, upgrade and maintain the network. -
Ease of use
Innovative Supervisory Slot-1 and Backup Slot-2 simplify chassis installation and maintenance tasks. -
Investment protection
Versatile multi-role platform designed for flexible Gigabit applications, 10G deployment and highly scalable core 10G applications. Each copper Gigabit blade can enable PoE+ or 30W or 60W UPOE via daughter card. -
Standard Management
Standard Command Line Interface (CLI), intuitive Web Interface (GUI), SNMP, Sflow and RSPAN. NMS300 transparent management platform with centralized firmware updates and mass-configuration support.
- NETGEAR RPS4000v2 - power enclosure
- Power enclosure - rack-mountable
- Rack Size
- 1U
- Localisation
- Europe, Americas
- Input Voltage
- AC 100-240 V
- 5-year warranty
- Designed For
- NETGEAR GSM7228PS, GSM7252PS, GSM7328Sv2, GSM7352Sv2, M4300-28G-PoE+; Next-Gen Edge Managed Switch M5300-28G, M5300-28GF3, M5300-52G
- Height (Rack Units)
- 1U
- Localisation
- Europe, Americas
- Supported Power Modules
- 4
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Cables Included
- 4 x power cable - external - 60 cm , 3 x power cable - external
- Rack Mounting Kit
- Included
- Limited warranty - 5 years
- Designed For
- NETGEAR GSM7228PS, GSM7252PS, GSM7328Sv2, GSM7352Sv2, M4300-28G-PoE+ , NETGEAR Next-Gen Edge Managed Switch M5300-28G, M5300-28GF3, M5300-52G
