NETGEAR roSafe 24-Port Gigabit L2 Managed Switch
Lifetime warranty
Quicklinx: 6LZGWS00 Mfr#: GSM7224-200EUS
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: Yes
POE: [N/A]
£268.76 ex VAT
£322.51 inc VAT
NETGEAR delivers wirespeed Gigabit performance and a full set of Layer 2 management features, as well as static routing with unsurpassed affordability. This high-speed switch delivers maximum throughput where you need it - to high-performance workgroups at the edge of the network, or as a backbone for Fast Ethernet switches and high-speed servers in demanding small networks. The non-blocking design offers full Gigabit throughput simultaneously to all 24 10/100/1000 ports to ensure reliable performance. Flexible fiber connectivity is enabled through four combination small form-factor pluggable (SFP) Gigabit interfaces. Layer 2 management functionality delivers reliability, control, and availability. Static routing enables inter-VLAN routing and provides a faster network and more effective bandwidth management. Access control lists (L2-L4) provide robust security, while L2-L4 based QoS provides enhanced traffic management capabilities. The cost-effective NETGEAR ProSafe 24-port Gigabit L2 Managed Switch creates a more productive - and future-proof - network. With increasing bandwidth requirements from applications such as voice, video, database management, and other services that slow throughput and response time, you can unleash your network and enable maximum productivity with Gigabit Ethernet for today's high-performance environments.
Optimize bandwidth, security, and control with full Layer 2 management capabilities. Network administrators can use any combination of these features to ensure uptime, availability, bandwidth and throughput.
  • Powerful
    Full 24 10/100/1000 ports and a non-blocking design provide wire speed throughput and maximum bandwidth for the most demanding network environments. Small form-factor pluggable (SFP) modules deliver choice in 1000BASE-SX, 1000BASE-LX or 1000BASE-ZX optics. The Layer 2 management features optimize bandwidth throughout the network - delivering Gigabit performance to systems, applications, and services. Take advantage of forwarding rates up to 71.4 million pps, and a switching capacity of 96 Gbps.
  • Easy to use
    Move up to Gigabit power in minutes. Use either of these solutions as a managed switch out of the box - just plug and play! All ports are auto-negotiating and support Auto Uplink technology. Choose from two easy-to-use management interface options - Web interface or a command line interface available through console or telnet. Comprehensive remote administration capabilities reduce the need for on-site administration. Easy to troubleshoot - built-in testing capability locates cable-related network problems.
  • Manageable
    Meet your management needs with SNMP (v1, v2c and v3), RMON, Command Line Interface (CLI) and completely redesigned Web-based GUI, ProSafe Control Center. Advanced features include up to 512 VLANs, DiffServ traffic prioritization and 802.1p (QoS) for Voice over IP services (VoIP), broadcast storm protection, RADIUS, 802.1x, port trunking, Rapid Spanning Tree, and link aggregation. In addition, L2-L4 based ACLs provide robust security, while static routing enables inter-VLAN routing for effective bandwidth management. Full Layer 2 implementation allows you to configure your network for maximum performance, reliability, and availability.
  • Outstanding
    These products offer Layer 2 management and full Gigabit power at a compelling price. Use at the edge to improve workgroup connections, or at the core to upgrade a Gigabit Ethernet backbone - now you can afford the power your network deserves. Like all NETGEAR products, everything you need is in the box - including rack-mount kit, power and serial cables, and more.
NETGEAR ProSAFE GSM7224v2 - switch - 24 ports - Managed
Switch - 24 ports - Managed
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x shared SFP
Performance
Bandwidth: 48 Gbps
Virtual interfaces (VLANs): 1024 , Static routes: 32
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
Flow control, Layer 2 switching, auto-negotiation, BOOTP support, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, manageable, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, MLD snooping, Dynamic ARP Inspection (DAI)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, ANSI/TIA-1057, IEEE 802.1ab (LLDP)
DC 12 V
Power Redundancy
44 cm x 20.5 cm x 4.3 cm
3.7 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Performance
Bandwidth: 48 Gbps
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Static IP routing
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB
Flash Memory
32 MB Flash (Firmware)
Status Indicators
Port transmission speed, power, link OK, RPS (Redundant Power Supply), link/activity, fan
24 x 1000Base-T RJ-45 , 1 x serial (RS-232) management , 4 x SFP (mini-GBIC)
Internal power supply
Power Redundancy
DC 12 V
38.5 Watt
4 rubber feet
1 x null modem cable
Rack Mounting Kit
Included
MTBF
239,032 hours
FCC Class A certified, C-Tick, cUL, VCCI Class A ITE, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, FCC Part 15, UL 60950-1
Europe
Software Included
Drivers & Utilities
44 cm
20.5 cm
4.3 cm
3.7 kg
55 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
6LZG C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
6LZG C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
6LZG C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.07
6LZG C2G 2m Cat6a Shielded Patch - Blue In Stock £7.44
Ports: 24
Managed: Yes
POE: [N/A]
Brand: NETGEAR
Price Range Ex VAT: 150 - 300
