NetGear ReadyYDATA 2U 12-Bay Expansion Unit
Quicklinx: 8TRYWS00 Mfr#: EDA2000-100WWS
Every ReadyDATA EDA2000 ships with a full suite of advanced features such as block-level replication, deduplication, and thin provisioning. Add expansion to as many as 180 TB and the dramatic perforce boost that comes from supporting a mix of SSD, SAS and SATA drives within a volume, and ReadyDATA redefines the concept of storage for small and medium businesses, remote offices/branch offices (ROBO), and departments within enterprise organizations.
Never before have so many features come standard on an enterprise-class storage device, especially one with a price tag that is comfortable for even the smallest of IT organizations. The ReadyDATA EDA2000 is easy-to-use unified storage from NETGEAR designed to address serious data management issues with a single system.
In addition to being simple for IT professionals to use, the all-inclusive feature set and simplified packaging of disk components make ReadyDATA an easy solution to sell for PowerShift partners.
  • Scalable capacity
    The ReadyDATA family of unified storage was built with the needs of a growing business in mind. ReadyDATA EDA2000 is 2U, 12-bay storage.
  • Peak performance
    For meeting the differing needs of specific applications, ReadyDATA EDA2000 users can mix-and match SATA, near-line SAS, SAS, and SSD drives within volumes to provide a stunning boost to performance and flexible capacity. Dual 10GbE ports and virtual network interface support ensure that even in I/O intensive virtual environments, network bottlenecks are a thing of the past. ReadyDATA EDA2000 also supports industry-standard file sharing protocols including iSCSI, CIFS, and NFS.
  • Advanced data management
    With data volume growing faster than ever before, the need to find more efficient ways to store and manage data is crucial. Unlike enterprise-class storage from traditional vendors, a full set of advanced data management technologies come standard with every ReadyDATA EDA2000.
NETGEAR ReadyDATA 2U Expansion Chassis EDA2000 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
SAS
0 (installed) / 12 (max)
Supported Drives
SATA-300 / SAS
Storage Controller
RAID (SATA 3Gb/s / SAS) - RAID 0, 1, 5, 6, 10
AC 120/230 V - 50/60 Hz
Power Redundancy
43.7 cm x 64.8 cm x 8.9 cm
16 kg
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SATA-300 / SAS
Storage
HDD Array External Interface
SAS
Storage Controller
RAID - integrated
Interface Type
SATA 3Gb/s / SAS
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
1 x SAS (input)
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
700 Watt
43.7 cm
64.8 cm
8.9 cm
16 kg
20 - 80% (non-condensing)
