ReadyNAS 626X desktop NAS with dual 10 Gigabit Ethernet ports is a no compromise high performance strorage system. It is the data storage solution of choice for offices that need the very best in capacity, performance and security. RN626X provides unmatched data protection, file sharing and sync capabilities for state-of-the-art backup and recovery, file serving and collaboration.
Bit Rot Protection
A proprietary technology, protecting your files from unplanned degradation. -
Unlimited snapshots
Unlimited data snapshot capability for on-box protection and flexible data recovery. -
XRAID2 and instant provisioning
Easily expand capacity and feel confident, knowing, that data is always protected. -
Cloud-managed replication
Maintain data sets in multiple locations or ensure protection of data from remote or branch office locations. -
iSCSI and thin provisioning
Powerful tools for a businesses, taking advantage of virtual infrastructures. -
Anti-virus and encryption
Keep data protected from outside threats and safe from prying eyes. -
Modern GUI and cloud/remote access from anywhere
Sleek modern interface and technology for secure remote access without configuration effort.
- NETGEAR ReadyNAS 626X - NAS server - 36 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Total Storage Capacity
- 36 TB
- Max Supported Capacity
- 60 TB
- Installed Devices / Modules Qty
- 6 (installed) / 6 (max)
- 19.2 cm x 28.8 cm x 25.9 cm
- Processor
- 1 x Intel Xeon D-1521 2.4 GHz (Quad-Core)
- Storage Controller
- 1 x RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 6 x 6 TB SATA 6Gb/s - Enterprise
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- ReadyNAS OS 6.5
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10
- 5-year warranty
- NAS server
- Host Connectivity
- 36 TB
- 60 TB
- 19.2 cm
- 28.8 cm
- 25.9 cm
- Built-in Devices
- Status LCD
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 8 GB DDR4
Storage Controller
- 1 x RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 6 x 6 TB
- Interface Type
- SATA 6Gb/s
- Enterprise
- Data Link Protocol
- TCP/IP, NTP, FTP, DHCP, Bonjour, SMB
- Remote Management Protocol
- SNMP 2, SNMP 3, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- Wake on LAN (WOL), E-mail alert, IPv6 support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, static IP mode, IPv4 support, dynamic IP mode, DHCP client, WebDAV server, Dropbox support, anti-virus protection
- Encryption Algorithm
- 256-bit AES
- IEEE 802.3ad (LACP), UPnP
- Expansion Bays
- 6 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x eSATA , 2 x Ethernet 10Gb - RJ-45
- MTBF
- 54,852 hours
- Security lock slot (cable lock sold separately), built-in cooling fan, UPS support, scheduled power on/off
- FCC Class B certified, RoHS, VCCI Class B
- Power Device
- Internal power supply
- Voltage Required
- 96 Watt
- Power Provided
- 200 Watt
- ReadyNAS OS 6.5
- OS Required
- Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
