Application data, virtual images, client files, email... the types of data central to running a successful business can seem endless. With ReadyNAS you finally have an advanced and easy-to use solution for centralizing, securing and controlling access to your digital assets. Way more than just simple unified (NAS and SAN) storage for your company, ReadyNAS allows you to do more than you ever thought you could afford by pairing the latest in performance with innovative efficiency technologies such as unlimited snapshots, thin provisioning and cloud-managed replication.
Every networked attached storage (NAS) device from NETGEAR runs on the revolutionary ReadyNAS operating system. This custom-built OS protects stored data with X-RAID automatic expansion and offers continuous data protection with unlimited snapshots. Real-time anti-virus and native encryption come standard while 10GbE ports are an option for certain 2U models. Designed specifically for the unique needs of business users, ReadyNAS devices utilize proprietary ReadyCLOUD technology for cloud-based discovery, provisioning and ongoing management. In addition, these devices are virtualization-ready with iSCSI support, thin provisioning capability and certification with VMware and Microsoft.
These days, your data is your world. With ReadyNAS, protecting and accessing that world has never been easier. ReadyNAS - Storage Made EASY.
- NETGEAR ReadyNAS 4312X - NAS server - 72 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Total Storage Capacity
- 72 TB
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- 44.5 cm x 70.7 cm x 8.8 cm
- 11.96 kg ()
- Processor
- 1 x Intel Xeon E3-1245V3 3.4 GHz (Quad-Core)
- Storage Controller
- 1 x RAID SATA 6Gb/s / eSATA RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 12 x 6 TB
- Networking
- 10Mb LAN, 100Mb LAN, GigE, 10 GigE
- RAM
- 16 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 5-year warranty
- NAS server
- Host Connectivity
- Enclosure Type
- 72 TB
- 44.5 cm
- 70.7 cm
- 8.8 cm
- 11.96 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 16 GB (installed) / 128 GB (supported) - DDR4
- Flash Memory Installed
- 256 MB
Storage Controller
- 1 x RAID
- Interface Type
- SATA 6Gb/s / eSATA
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 12 x 6 TB
- Data Link Protocol
- TCP/IP, NTP, DHCP, Bonjour
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- Dynamic IP address assignment, trunking, load balancing, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, IPv6 support, event log, Jumbo Frames support, DLNA Media Server, Apple Time Machine compatible, LACP support, Link Aggregation Control Protocol (LACP), DHCP client, WebDAV server, anti-virus protection
- Encryption Algorithm
- SSL, 256-bit AES
- IEEE 802.3ad (LACP), UPnP
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 , 2 x SAS , 2 x eSATA , 2 x Ethernet 10Gb - RJ-45
- MTBF
- 159,519 hours
- Built-in 3 cooling fans, X-RAID2 technology
- FCC Class A certified, RoHS, VCCI Class A
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 163 Watt
- Power Provided
- 550 Watt
- Limited warranty - 5 years
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 30 dBA
