Application data, virtual images, client files, email... the types of data central to running a successful business can seem endless. With ReadyNAS you finally have an advanced and easy-to use solution for centralizing, securing and controlling access to your digital assets. Way more than just simple unified (NAS and SAN) storage for your company, ReadyNAS allows you to do more than you ever thought you could afford by pairing the latest in performance with innovative efficiency technologies such as unlimited snapshots, thin provisioning and cloud-managed replication.
Every networked attached storage (NAS) device from NETGEAR runs on the revolutionary ReadyNAS 6 operating system. This custom-built OS protects stored data not only with automatic RAID configuration, but is the first of its kind to feature the continuous data protection of unlimited snapshots along with real-time anti-virus and native encryption. Designed with ease-of-use in mind, ReadyNAS devices utilize proprietary ReadyCLOUD technology for cloud-based discovery, provisioning and even ongoing management.
Unlimited snapshots
Unlimited data snapshot capability for on-box protection and flexible data recovery. -
iSCSI and thin provisioning
Powerful tool is design for a businesses taking advantage of virtual infrastructures. -
XRAID2 & instant provisioning
Easily expand capacity and feel confident knowing that data is always protected. -
Anti-virus & encryption
Keep data protected from outside threats and safe from prying eyes. -
Cloud-managed replication
Maintain data sets in multiple locations or ensure protection of data from remote or branch office locations. -
Modern GUI and ReadyCLOUD management
Sleek, modern interface that puts the tools you need, where and when you need them.
- NETGEAR ReadyNAS 2120 RN2120v2 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 1U
- Max Supported Capacity
- 24 TB
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- 28.5 cm x 34 cm x 4.4 cm
- 4.19 kg ()
- Processor
- 1 x Marvell ARMADA XP 1.6 GHz (Dual-Core)
- Storage Controller
- 1 x RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- Automatic backup, Exclusive-OR (XOR), Data Protection Technology
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- ReadyNAS OS 6
- 5-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 24 TB
- 28.5 cm
- 34 cm
- 4.4 cm
- 4.19 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- RAM
- 2 GB DDR3
- Flash Memory Installed
- 128 MB
Storage Controller
- 1 x RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap - 2.5" / 3.5" shared
- S.M.A.R.T.
- Data Link Protocol
- TCP/IP, NTP, SMTP, FTP, DHCP, Bonjour, SMB, NFS
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Load balancing, VLAN support, wake on LAN (WOL), IPv6 support, server health monitoring, file sharing, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, static IP mode, Thin Provisioning, bandwidth control, IPv4 support, Apple Time Machine compatible, LACP support, Link Aggregation Control Protocol (LACP), dynamic IP mode, DHCP client, WebDAV server, static routing, cloud managed, Dropbox support, NAS support, anti-virus protection
- Encryption Algorithm
- SSL, TLS, 256-bit AES
- IEEE 802.3ad (LACP), DLNA CERTIFIED, UPnP
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 , 1 x USB 2.0 , 2 x eSATA
- Automatic server restart (ASR), remote control, application snapshots, built-in 3 cooling fans, X-RAID2 technology, LED indicator, UPS support, volume control, software encryption, auto shutdown circuit, VMware Ready, VPN support
- FCC Class B certified, RoHS, VCCI Class B, TLS
- Power Device
- Internal power supply
- Voltage Required
- 38 Watt
- ReadyNAS OS 6
- Limited warranty - 5 years
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
