NetGear ProSecure UTM150 Bundle 1 Year Subscription
Quicklinx: 858XWS00 Mfr#: UTM150EW-100EUS
ProSecure Unified Threat Management (UTM) appliances combine performance with comprehensive security coverage for small businesses. The flexible modular software design architecture leverages patent-pending Stream Scanning technology to scan files and data streams up to 5x faster than conventional methods. This architecture in turn enables ProSecure UTM to utilize virus and malware threat databases from NETGEAR and Sophos that are over a million signatures in size - up to 400x more comprehensive than legacy small business UTM platforms.
NETGEAR ProSecure Unified Threat Management Appliance UTM150 - security appliance - with 1 year Web, 1 year Email, and 1 year Software Maintenance and Upgrades, 24/7 Support, and Advanced Replacement
Security appliance
Bundled Services
External - 1U
Europe
Ports Qty
4
Performance
Antivirus throughput: 130 Mbps , Stateful throughput: 900 Mbps , VPN throughput: 400 Mbps
Simultaneous users: 150 , Concurrent connections: 65000 , VPN tunnels (site-to-site): 150 , SSL VPN tunnels: 75
VoIP Protocols
SIP
Security appliance
Bundled Services
Height (Rack Units)
1U
Europe
External
Ports Qty
4
Wired
Network / Transport Protocol
PPTP, NTP, IPSec, PPPoE, SMTP, FTP, DHCP, DNS, POP3, IMAP4
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 2c, HTTP, HTTPS
Performance
Firewall protection, DMZ port, routing, dynamic IP address assignment, DHCP support, NAT support, PAT support, LDAP support, VLAN support, auto-uplink (auto MDI/MDI-X), Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, VPN passthrough, Intrusion Prevention System (IPS), URL filtering, IP address filtering, anti-spam protection, anti-malware protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), DHCP server
Encryption Algorithm
DES, Triple DES, RSA, MD5, IKE, SHA-1, TLS 1.0, SSL 3.0, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, Active Directory
IP Telephony
VoIP Protocols
SIP
4 x 1000Base-T - RJ-45 , 4 x 1000Base-T - RJ-45 (WAN) , 1 x USB , 1 x management
Rack Mounting Kit
Included
FCC Class A certified, RoHS, WEEE
Internal power supply
Extended service agreement - replacement - 1 year , Technical support - consulting - 1 year , New releases update - 1 year , Virus definitions update - 1 year , Intrusion definitions update - 1 year
