ProSecure Unified Threat Management (UTM) appliances combine performance with comprehensive security coverage for small businesses. The flexible modular software design architecture leverages patent-pending Stream Scanning technology to scan files and data streams up to 5x faster than conventional methods. This architecture in turn enables ProSecure UTM to utilize virus and malware threat databases from NETGEAR and Sophos that are over a million signatures in size - up to 400x more comprehensive than legacy small business UTM platforms.
- NETGEAR ProSecure Unified Threat Management Appliance UTM150 - security appliance
- Security appliance
- Form Factor
- External - 1U
- Localisation
- Europe
- Ports Qty
- 4
- Data Link Protocol
- Performance
- Antivirus throughput: 130 Mbps , Stateful throughput: 900 Mbps , VPN throughput: 400 Mbps
- Capacity
- Simultaneous users: 150 , Concurrent connections: 65000 , VPN tunnels (site-to-site): 150 , SSL VPN tunnels: 75
- VoIP Protocols
- SIP
- Power
- AC 120/230 V (50/60 Hz)
- 2-year warranty
- Height (Rack Units)
- 1U
- Localisation
- Europe
- Form Factor
- External
- Ports Qty
- 4
- Connectivity Technology
- Wired
- PPTP, NTP, IPSec, PPPoE, SMTP, FTP, DHCP, DNS, POP3, IMAP4
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- SNMP 2c, HTTP, HTTPS
- Performance
- Capacity
- Firewall protection, DMZ port, routing, dynamic IP address assignment, DHCP support, NAT support, PAT support, LDAP support, VLAN support, auto-uplink (auto MDI/MDI-X), Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, VPN passthrough, Intrusion Prevention System (IPS), URL filtering, IP address filtering, anti-spam protection, anti-malware protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), DHCP server
- Encryption Algorithm
- DES, Triple DES, RSA, MD5, IKE, SHA-1, TLS 1.0, SSL 3.0, PKI, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, LDAP, Active Directory
IP Telephony
- VoIP Protocols
- SIP
- 4 x 1000Base-T - RJ-45 , 4 x 1000Base-T - RJ-45 (WAN) , 1 x USB , 1 x management
- Rack Mounting Kit
- Included
- FCC Class A certified, RoHS, WEEE
- Power Device
- Internal power supply
- Voltage Required
- Limited warranty - 2 years
