NETGEAR ProSAFE XS748T 48 Port 10G Smart Switch
48 PORT 10-GIGABIT MANAGED SWITCH
Quicklinx: C4NPWS00 Mfr#: XS748T-100NES
Type: 10 Gigabit Ethernet
Ports: 48
Managed: Yes
£2,650.74 ex VAT
£3,180.88 inc VAT
The XS748T 10-Gigabit Ethernet Smart Managed Switch brings the second generation of 10-Gigabit Copper switching to SMBs. The XS748T is a powerful Smart Managed Switch that includes 44 ports of 10-Gigabit connectivity (44 copper with 4 dedicated 10-Gigabit SFP+ Fiber ports). NETGEAR's 10-Gigabit Smart Managed Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. The XS748T provides comprehensive L2+/Layer 3 Lite features (including IPV6 management) allowing SMB customers to deploy virtualization, cloud-based services and applications like VoIP, video streaming and IP surveillance, which require higher reliability, speed, and performance. It can be used at the "center of a small business network" or as an aggregation/access switch in a larger organization. The XS748T is ideal for is ideal for expanding network capacity, removing performance bottlenecks and/or support of premise expansion needs.
  • Comprehensive L2+ / Layer 3 Lite features
    The ProSAFE 10G Smart Managed Switch provides comprehensive L2+ / Layer 3 Lite features in order to meet current and future needs on virtualization, converged networking and mobility.
  • Smart IT, not big IT
    Easy-to-use web browser-based management GUI makes setup and management simple. It features a standards-based technology, ensuring interoperability with any standards-based devices in the existing network, as well as dual firmware images, improving reliability and uptime to your network.
  • 10-Gigabit transition with BASE-T
    10GBASE-T, like other BASE-T technologies, uses the standard RJ-45 Ethernet jack. It is backward compatible, auto-negotiating between higher and lower speeds - thereby not forcing an all-at-once network equipment upgrade.
NETGEAR XS748T - switch - 48 ports - smart - rack-mountable
Switch - 48 ports - L3 Lite - smart
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
44 x 10GBase-T + 4 x 10 Gigabit SFP+
Performance
Switching fabric bandwidth: 960 Gbps , Forwarding performance (64-byte packet size): 238 Mpps
ACL: 164 , Virtual interfaces (VLANs): 512 , IGMP groups: 512 , IPv4 routes: 64 , IPv6 routes: 64 , Priority queues per port: 8 , ARP entries: 1024 , DHCP snooping entries: 1000
MAC Address Table Size
16K entries
Jumbo Frame Support
10KB
Routing Protocol
Static IPv4 routing, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IP address filtering, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, reset button, LACP support, LLDP support, Port Security, DHCP client, Energy Efficient Ethernet, Strict Priority Queuing (SPQ), Class of Service (CoS), 802.1x authentication, Type of Service (ToS), DiffServ Code Point (DSCP) support, 4 fans, 3MB packet buffer, cable test, layer 2+ switching
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az
44 cm x 31 cm x 4.3 cm
6.25 kg
Latin America, North America, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
10KB
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 2.0, TLS 1.2
Authentication Method
RADIUS, TACACS+
: 800 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Port transmission speed, power, link/activity, fan
44 x 10GBase-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x USB 2.0 management
Internal power supply
262.8 Watt
Rubber feet
Rack Mounting Kit
Included
MTBF
483,808 hours
cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, CISPR 22, CCC, FCC Part 15 A, C-Tick Class A, SCC, VCCI Class A, TLS v1.2, TLS v1.0
Software Included
Drivers & Utilities
44 cm
31 cm
4.3 cm
6.25 kg
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
C4NP C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
C4NP C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
C4NP C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.56
C4NP C2G 2m Cat6a Shielded Patch - Blue In Stock £7.11
Ports: 48
Managed: Yes
Brand: NETGEAR
Price Range Ex VAT: 1500+
