Your basket is empty
NetGear ProSAFE WNDAP660 Dual Band Wireless-N Access Point
Lifetime warranty
Quicklinx: 840RWS00 Mfr#: WNDAP660-100UKS
Type: Radio access point
Connectivity: Wireless
Speed: 450Mbps
Protocol: IEEE 802.11n
Compatibility: Unix
  • IEEE 802.11n
£185.11 ex VAT
£222.13 inc VAT
The NETGEAR WNDAP660 AP supports 3 x 3 multiple-input multiple-output (MIMO) with three spatial streams to deliver up to 50% faster throughput speeds and improved service area coverage. Advanced wireless security with Wireless Intrusion Prevention Services (WIPS), Wireless Intrusion Detection Services (WIDS) and RF management make the NETGEAR access point the economical solution for small-and mid-sized businesses seeking a secure and efficient way to manage their multi-faceted wireless traffic needs.
NETGEAR ProSafe Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660 - radio access point
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Connection / user qty: 128
Power Over Ethernet (PoE) Supported
PoE+
25.38 cm x 25.38 cm x 5.48 cm
1.5 kg
NETGEAR lifetime warranty
Radio access point
25.38 cm
25.38 cm
5.48 cm
1.5 kg
United Kingdom
External
Wireless
Data Transfer Rate
450 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, LAN, wireless, link/activity
Auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, MIMO technology, wall mountable, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, wireless bridge mode, LLDP support, rogue access point detection, ceiling mountable, Wireless Intrusion Prevention System (WIPS)
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
Secure Shell (SSH), RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.3at
Aerial
Antenna
Internal
Antenna Qty
2
Gain Level
2 dBi
2 x 1000Base-T - RJ-45 , 3 x aerial , 1 x management - RJ-45
1 x network cable
Mounting Kit
Included
PoE+
External power adapter
Software Included
Drivers & Utilities
Speed: 450Mbps
Compatibility: Unix
Brand: NETGEAR
Price Range Ex VAT: 150 - 300
