NetGear ProSAFE WN370 Wall Mount Wireless-N Access Point
LIFETIME WARRANTY
Quicklinx: 9KLZWS00 Mfr#: WN370-10000S
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11ac (draft 2.0), IEEE 802.11b, IEEE 802.11g
Compatibility: Mac, PC
Hurry, only 3 left in stock!
£99.19 ex VAT
£119.02 inc VAT
Affordable, wired and wireless (802.11n single band 2.4 GHz) Access Point for small and medium hotels and K-12 dormitories. Sleek, elegant, and compact design allows AP to be deployed in an inconspicuous manner. Can be install in less than 5 minutes with a non- technical personnel and the Access Point is powered by Power Over Ethernet (1Gbps) to reduce cabling cost and time for deployments. WN370 comes with 4 (100Mbsp) Ethernet data ports and one Voice pass through voice port for connectivity of digital phones that requires native access to an in-house PBX system. It has centralized management with WC7600 Wireless Controllers for automatic RF and power tuning with guest access captive portal and comprehensive wireless securities.
  • Small form factor and inconspicuous appearance
    The aesthetically pleasing design of the WN370 allows the access point to blend nicely in the hotel room and school dormitories. WN370 provides wired access directly to the users, where the traditional form factor Access Points are normally installed on the ceiling, away from the access of the users that need wired connectivity. The WN370 is installed with easy attachment to the junction box and appears with a nice decorative appearance.
  • Fast installation and PoE powered
    The WN370 can be installed easily and less than 5 minutes. The WN370 is powered via Power over Ethernet on the 1 Gbps uplink. Simply connect a Ethernet cable between the WN370 and a PoE enabled switch and the WN370 is up and running. There is no separate power cord needed.
  • Flexible and easy deployment
    WN370 can be installed easily and does not need sophisticated skills of engineers. WN370s are generally deployed in room, especially effective in areas where deploying the access points in traditional locations (such as ceiling mounted or hallways of dormitories and hotels) are not feasible. Because the WN370 is designed to provide coverage in a specific room, where the RF containment is more well defined, no extensive site survey is required. Finally, because the WN370 comes with four Ethernet ports, users can plug in multiple wired devices without the requirement to pull additional cables from the access point to the wiring closet, thereby saving both time and money to meet the requirements of multiple Ethernet ports per room.
NETGEAR WN370 - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11ac (draft 2.0)
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
9.31 cm x 13.52 cm x 2.59 cm
218 g
NETGEAR lifetime warranty
Radio access point
9.31 cm
13.52 cm
2.59 cm
218 g
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP 1, SNMP 2
Frequency Band
2.4 GHz
Status Indicators
Power, status, WLAN
VLAN support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, rogue access point detection, Captive Portal, Auto Healing
Encryption Algorithm
WPA, WPA2, WEP
Authentication Method
RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.11, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft 2.0)
Aerial
Antenna
Internal
1 x 1000Base-T (PoE) - RJ-45 , 4 x 1000Base-T - RJ-45 , 1 x 100Base-TX
PoE
External power adapter
9KLZ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
9KLZ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
9KLZ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.51
Speed: 300Mbps
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Compatibility: Mac
Compatibility: PC
Brand: NETGEAR
Price Range Ex VAT: 50 - 100
