Product
Brand
NetGear Prosafe Wireless N Access Point
Lifetime warranty
Quicklinx: 8V7RWS00 Mfr#: WNAP210-200UKS
  • IEEE 802.11n (draft 2.0)
Jump up to Wireless N without leaving 11g behind.
Backward compatible to 802.11g devices, the WNAP210 simultaneously provides faster wireless networking for 802.11n devices - up to 10x the coverage and 15x the speed.
Advanced Speed and Range with Comprehensive Internet Security
  • Up to 10x the coverage and 15x the speed of 802.11g networks
  • Backward compatible to 802.11g devices while simultaneously providing faster wireless networking for 802.11n devices
  • Security features include WPA, WPA2, rogue AP detection and 802.1x with RADIUS support
  • Can run on 802.3af PoE for easy placement in optimal locations- desktop, wall-mount or ceiling
  • Internal antennas for optimized antenna configuration without user guesswork
  • Comprehensive SNMP functionality for advanced network management
  • Deploy over large areas with point-to-point and point-to-multipoint bridging over large areas with Wireless Distribution System (WDS)
  • Mounting kit provides for wall or ceiling placements
NETGEAR ProSafe Wireless-N WNAP210 v2 - radio access point
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
Vertical stand
Power Over Ethernet (PoE) Supported
PoE
22.35 cm x 15.32 cm x 2.8 cm
410 g
NETGEAR lifetime warranty
Radio access point
22.35 cm
15.32 cm
2.8 cm
410 g
United Kingdom
External
Wireless
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS, SSH, CLI
Frequency Band
2.4 GHz
Status Indicators
Power, test mode, WLAN, LAN
Auto-sensing per device, power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, Multiple SSID support, hidden SSID, wireless bridge mode, rogue access point detection
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID), Basic Service Set Identifier (BSSID), Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
Aerial
Antenna
Internal
1 x 1000Base-T - RJ-45
Vertical stand
1 x network cable
Mounting Kit
Included
PoE
External power adapter
Software Included
Drivers & Utilities
