NETGEAR Stackable, PoE Managed Gigabit switch GSM7252PS allows the most flexible and easy-to-deploy Gigabit Power over Ethernet infrastructure. All the 48 ports of 10/100/1000 Mbps interfaces support 802.3af PoE standard with a comfortable 384 watts total budget. Two built-in 10 Gigabit Ethernet SFP+ interfaces on the front and two additional 10 Gigabit module bays on the rear, permitting both uplinks and local/distant stacking, provide versatile 10 Gigabit deployment possibilities.
Combining superior resiliency, enterprise-class security and non-blocking performance, NETGEAR Stackable PoE Managed Gigabit switch GSM7252PS offers a full set of layer 2 management features, as well as layer 2+ (layer 3 lite - IPv4 routing) with unsurpassed affordability. The GSM7252PS series can be deployed at enterprise edge, remote branch offices and closer to the core of small and medium businesses' growing networks.
Enterprise-class L2+
Combining superior resiliency, enterprise-class security and non-blocking performance, NETGEAR Stackable PoE Managed Gigabit switch GSM7252PS offers a full set of layer 2 management features, as well as layer 2+ (layer 3 lite - IPv4 routing) with unsurpassed affordability. The GSM7252PS series can be deployed at enterprise edge, remote branch offices and closer to the core of small and medium businesses' growing networks. -
L3 scalability
Designed for enterprise networks and core/aggregation levels of SMB networks, L3 upgraded GSM7252PS provides advanced routing protocols such as OSPF, VRRP and multicast for converged applications. -
High availability
NETGEAR Stackable, PoE Managed Gigabit switch GSM7252PS comes with a removable power module for the main power supply. In the event of a power supply failure, the switch can immediately shift to an external RPS device while the internal power module is replaced for 100% uptime.
- NETGEAR GSM7252PS - switch - 48 ports - Managed
- Switch - 48 ports - L2+ - Managed - stackable
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 (PoE+) + 4 x shared SFP + 2 x SFP+ + 40 x 10/100/1000 (PoE)
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 384 W
- MAC Address Table Size
- 8K entries
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2
- Flow control, Layer 2 switching, power over Ethernet (PoE), BOOTP support, ARP support, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, manageable, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, Dynamic ARP Inspection (DAI)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1v, ANSI/TIA-1057, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 39.1 cm x 4.3 cm
- 6.8 kg
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 384 W
- 8K entries
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- TLS 1.0, SSL 3.0
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Processor
- : 666 MHz
- RAM
- 256 MB
- Flash Memory
- 32 MB Flash (Firmware)
- Status Indicators
- Port transmission speed, power, link OK, status, link/activity
- 40 x 1000Base-T RJ-45 PoE , 1 x serial (RS-232) DB-9 management , 4 x Gigabit LAN SFP , 2 x 10Gbit LAN SFP+ , 8 x 1000Base-T RJ-45 PoE+ - 30 W
- Expansion Slots
- 2 (total) / 2 (free) x Expansion Slot
- Power Device
- Internal power supply - hot-plug
- Voltage Required
- Redundant Power System (RPS) connector
- Cables Included
- 1 x null modem cable
- Rack Mounting Kit
- Included
- MTBF
- 169,522 hours
- CISPR 22 Class A, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, FCC Part 15 A, C-Tick Class A
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- 44 cm
- 39.1 cm
- 4.3 cm
- 6.8 kg
- 0 °C
- 50 °C
- 0 - 90%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
