Your basket is empty
NETGEAR ProSafe GSM7352Sv2 - switch - 48 ports - Managed - desktop
Lifetime warranty
Quicklinx: 7VK2WS00 Mfr#: GSM7352S-200EUS
NETGEAR's low-cost, stackable Gigabit Ethernet switches deliver maximum throughput and flexibility where you need it - to high-speed, high-density workgroups at the edge of the network, in the backbone of growing networks or for bandwidth-thirsty file and application servers. The ProSafe GSM7352S fully-managed switch delivers 48 ports of auto-sensing 10/100/1000 Mbps interfaces for high-density copper connectivity.
The ProSafe GSM7352S has two 10 Gigabit Ethernet small form-factor pluggable (SFP+) interfaces and two high-speed, module bays offering modular expansion for 10 Gigabit Ethernet or 48 Gigabit Stacking connectivity. The non-blocking design of the switches delivers simultaneous, full wire-speed, low-latency throughput to all ports.
A full suite of Layer 3 switching functionality ensures reliable routing between VLANs and network segmentation where and when you need it, at no additional cost. By configuring the switches into a stack of up to 8 units across a 48 Gbps bi-directional ring, a high-density, single IP-addressable switch can be built.
Robust security features include IEEE 802.1x port-based authentication and access control lists, ensuring that only authorized users can access your network. Secure management of the switches is available through Secure Sockets Layer (SSLv3) for the Web GUI and Secured Shell (SSH) for command-line sessions or with SNMP v3 for network management software. For workgroup deployments in cost-sensitive organizations that require Layer 3 switching, additional Gigabit capacity, high-value price point, flexibility of stacking, and reduced maintenance requirements, NETGEAR's ProSafe Gigabit Layer 3 Stackable switches deliver the ideal access-edge solution.
With their high-value price point, flexible design, and reduced maintenance requirements, NETGEAR's ProSafe Gigabit Layer 3 Stackable switch solutions yield a high return on investment, and are ideal for delivering highly reliable, converged voice, video, and data services over a single network infrastructure.
NETGEAR ProSAFE GSM7352Sv2 - switch - 48 ports - Managed
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x shared Gigabit SFP + 2 x SFP+
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, SSH-2
Flow control, Layer 3 switching, Layer 2 switching, auto-sensing per device, DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, DiffServ support, store and forward, Broadcast Storm Control
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1v
44 cm x 39.1 cm x 4.3 cm
6.8 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
8K entries
Jumbo Frame Support
9KB
Max Units In A Stack
8
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
RADIUS, Secure Shell v.2 (SSH2)
RAM
256 MB
Flash Memory
32 MB Flash
Status Indicators
Port transmission speed, power, link OK, Unit ID, status, RPS (Redundant Power Supply), link/activity, fan
48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x USB Type A , 4 x SFP (mini-GBIC) , 2 x SFP+
Expansion Slots
2 (total) / 2 (free) x Expansion Slot
Internal power supply
114 Watt
Redundant Power System (RPS) connector
1 x null modem cable
Rack Mounting Kit
Included
MTBF
83,550 hours
FCC Class A certified, C-Tick, CISPR 22 Class A, cUL, EN 60950, UL 1950, IEC 60950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, FCC Part 15
Europe
Software Included
Drivers & Utilities
44 cm
39.1 cm
4.3 cm
6.8 kg
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
7VK2 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.09
7VK2 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.60
7VK2 C2G 2m Cat6a Shielded Patch - Blue In Stock £6.53
7VK2 C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.38
