NetGear ProSafe GS116E Plus Switch 16 Port Gigabit Ethernet
LIFETIME WARRANTY
Quicklinx: B2DTWS00 Mfr#: GS116E-200UKS
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
34 in stock
£69.55 ex VAT
£83.46 inc VAT
The Prosafe Plus switch is an upgrade to unmanaged switch which can only Plug-N-Play, and is not configurable. Prosafe Plus switch gives user the flexibility to configure certain static layer 2 settings to better fit their needs. The GS116E is a 16-port Gigabit switch.
GS116E supports loop detection. When a loop is detected, the both LED on the affected port will blink at a constant speed with roughly 1 every second. Dos is a form of attack on computer network resources. The Auto Dos feature of GS116E would automatically block malicious packets such as source IP equals destination IP.
NETGEAR Plus GS116Ev2 - switch - 16 ports - Managed
Switch - 16 ports - Managed
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Jumbo Frame Support
Remote Management Protocol
HTTP
Flow control, auto-negotiation, IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, Quality of Service (QoS), reset button, loop prevention
28.6 cm x 10.1 cm x 1.59 cm
0.84 kg
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Jumbo Frame Support
HTTP
Status Indicators
Port status, power
16 x 1000Base-T RJ-45
External power adapter
10 Watt
FCC Class A certified, C-Tick Class A, KC, VCCI Class A, CCC Class A
United Kingdom
28.6 cm
10.1 cm
1.59 cm
0.84 kg
50 °C
10 - 90% (non-condensing)
B2DT C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
B2DT C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.25
B2DT C2G 2m Cat6a Shielded Patch - Blue In Stock £7.45
Ports: 16
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: 50 - 100
