NETGEAR ProSafe Dual Band Wireless-N Access Point
Lifetime warranty
Quicklinx: 6M9QWS00 Mfr#: WNDAP350-100UKS
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Compatibility: Mac, PC, Unix
  • IEEE 802.11n (draft 2.0)
£137.76 ex VAT
£165.31 inc VAT
Advanced Speed and Range with Comprehensive Internet Security
With Concurrent dual-band operation, comprehensive security, and quality of service, the ProSAFE® WNDAP350 is the Wireless-N workhorse a growing SMB needs.
Performance
- Up to 15x the speed and 10x the coverage of 802.11a, 802.11g networks
- Operation in 5 GHz radio band to avoid interference from 802.11b or 802.11g network devices
- Concurrent operation in 2.4 GHz and 5 GHz radio band
- Support for 802.3af PoE for optimal placement of access point
Supreme Business Value
- Backward compatibility with 802.11a, 802.11g and 802.11b network devices
- Comprehensive SNMP functionality for advanced network management
- Deploy wireless coverage over large areas with point-to-point and point-to-multipoint bridging via Wireless Distribution System (WDS)
- Lifetime hardware warranty
- Metal case includes Kensington lock slot for anti-theft
Robust Security
- Security features include WPA, WPA2, rogue AP detection and 802.1x with RADIUS support
- Optimal solution for deployment in hardened locations
Ease of Use
- Intuitive interface simplifies management
- Integrated 802.3af PoE eliminates extra cables and enables optimal placement of the access point
- Antenna take-offs enable optional accessory antenna attachment for 2.4 GHz operations
- Plenum-rated for safe and convenient placement above drop-down ceilings
  • Performance
    Wireless N with Concurrent dual band operation with quality of service.
  • Mobility
    Up to 15x the speed and 10x the coverage of legacy products.
  • Security
    Full enterprise security with WAP, WPA2, 802.1x with Radius and built in rogue AP detection.
NETGEAR Dual Band Wireless-N Access Point WNDAP350 - radio access point
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
UNIX, Apple MacOS, Linux, Microsoft Windows 98/ME/2000/XP/Vista
Power Over Ethernet (PoE) Supported
PoE
NETGEAR lifetime warranty
Radio access point
United Kingdom
External
Wireless
Remote Management Protocol
SNMP, Telnet, HTTP, SSH
Status Indicators
Power, link OK, test mode, link/activity
Power over Ethernet (PoE), VPN support, auto-uplink (auto MDI/MDI-X), repeating mode, VPN passthrough, Wireless Distribution System (WDS) support, wireless bridge mode
Encryption Algorithm
128-bit WEP, 64-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
Secure Shell (SSH), RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
Aerial
Antenna
Internal
Antenna Qty
1
1 x 1000Base-T - RJ-45 , 1 x management - DB-9
1 x network cable
Mounting Kit
Included
PoE
External power adapter
Software Included
Drivers & Utilities
6M9Q C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
6M9Q C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
6M9Q C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.95
6M9Q C2G 2m Cat6a Shielded Patch - Blue In Stock £7.33
Speed: 300Mbps
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n (draft 2.0)
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Brand: NETGEAR
Price Range Ex VAT: 100 - 150
