Advanced Speed and Range with Comprehensive Internet Security
- 3 x 3 multiple-input, multiple-output (MIMO) with three spatial streams.
- Dual band selectable in 2.4 or 5 GHz radio band for maximum wireless throughput.
- Stylish and elegant design with easy mounting options (e.g. ceiling, wall and desktop).
- Backward compatibility with 802.11a, 802.11g and 802.11b network devices.
- Integrated Power over Ethernet (IEEEĀ® 802.3af and 802.3at PoE) lowers deployment costs.
- Deploy wireless coverage over large areas with point-to-point and point-to-multipoint bridging via Wireless Distribution System (WDS).
- Security features include WPA, WPA2, rogue AP detection and 802.1x with RADIUS support.
- Internal antennas factory-optimized for maximum RF performance.
- Advanced Security with Wireless Intrusion Detection (WIDS) and Wireless Intrusion Prevention (WIPS) support.
- 802.11n Beamforming to improve range and maximizes data rates.
- Device-based QoS to provide differentiated service level agreement to each user and device type.
- NETGEAR Dual Band Premium Wireless-N Access Point WNDAP620 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Connection / user qty: 50
- Power Over Ethernet (PoE) Supported
- PoE+
- 25.38 cm x 25.38 cm x 5.48 cm
- 1.5 kg
- NETGEAR lifetime warranty
- 25.38 cm
- 25.38 cm
- 5.48 cm
- 1.5 kg
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 450 Mbps
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, SSH, CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Status Indicators
- Power, LAN, wireless, link/activity
- VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, MIMO technology, wall mountable, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, wireless bridge mode, LLDP support, rogue access point detection, ceiling mountable, Wireless Intrusion Prevention System (WIPS)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
- Authentication Method
- Secure Shell (SSH), RADIUS, Extensible Authentication Protocol (EAP)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.3at
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Gain Level
- 2 dBi
- 1 x 1000Base-T - RJ-45 , 3 x aerial , 1 x management - RJ-45
- Cables Included
- 1 x network cable
- Mounting Kit
- Included
- PoE+
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities
